Diy: CR-X to BB6 cluster swap
Old Aug 23, 2012 | 06:43 PM
H22BB6's Avatar
Default Diy: CR-X to BB6 cluster swap
How to: BB6 cluster into CR-X
What: Installing the gauge cluster out of the 97-01 Honda Prelude into a CR-X
Tools and Materials: Phillips screw driver, 10mm socket, good wire strippers, electrical tape, heat shrink, solder and soldering iron. Most of all patients Cause it can get tight in there. I did mine with the dash harness out of the car.
Step 1. (Assuming you’ve removed your old cluster already) There’s minimal shaving of the dash needed (like a 1/8th of an inch probably less) to get it sit perfectly like the EF cluster does. I used a dremel not shown here.
drivers side trimming
passenger side trimming
Step 2. You have to remove these metal brackets to get the cluster to sit flush (not my pic borrowed from the 99 SI cluster thread)
Step 3. Now comes the fun part the wiring. Since nobodies done this before or at least documented a step-by-step how to.
Here’s your CR-X wiring and what wire does what
90-91
E6 is you door open warning light
88-89
C12 is you door open warning light
Now for the prelude wiring
ignore the D plug and pins A9, A11 C5, C6, C12. And for some reason i didn't have A10 or C9 but my gauge cluster pig tails are from the jdm prelude type s so that could be why.
Also remove the bulbs from the srs and Abs light cause they'll stay on and its a little annoying
Since I’m a nice guy here’s the wiring done for the 90-91
wiring for the 88-89 guys
Step 4. cable To electronic Vehicle Speed Sensor
since I never had a cable vss to begin with so I also borrowed this from the Si cluster swap thread
Step 5. Wiring the vss
Now for wiring the electronic Vehicle Speed Sensor is the same as below except instead of pin b6 the signal wire goes to pin B3
First off I believe it looks better than the gsr and civic si clusters and it fits better without cutting off part of the temp and fuel gauge. It’s also the same shape as the 90-91 cluster hood so it sits in like it was meant to be. For the most part it’s pretty straight forward. Most of the wires it’s just matching them up.
Finished pictures
Hard to see but the gauge lights are on
and again ignore to auto cluster I'll be putting the manual cluster in sometime this week
Old Aug 23, 2012 | 07:02 PM
ryanevansoh's Avatar
Default Re: Diy: CR-X to BB6 cluster swap
Good thourough write-up! Looks like a clean installation too.
Old Aug 24, 2012 | 01:18 PM
tonylovesjdmEF9's Avatar
Why is the abs light on??
Old Aug 24, 2012 | 03:18 PM
dickdragon's Avatar
Great job! I'm still debating on the em1 or this one.
Old Aug 25, 2012 | 07:56 PM
H22BB6's Avatar
abs and srs light were on because there's no abs or srs system detected. Remedy remove bulbs.
Thanks! I'd say do it cause its much different then everyone else's who does the cliche EM1 or integra cluster.
Old Aug 25, 2012 | 08:14 PM
t-town_ep's Avatar
OMG!! That is awesome!!! Great work man!
Old Aug 25, 2012 | 08:17 PM
Vagitarian's Avatar
Does look sick, but the wiring looks confusing, especially if you cant/dont wanna remove the dash harness and would have to do it in car
Old Aug 27, 2012 | 08:47 AM
H22BB6's Avatar
wiring difficulty in-car is the same as doing the integra or em1 cluster. I admit I did mine with the cluster harness out of the car and it is much easier that way.
scottmog
Aug 22, 2008 07:53 AM
ek4oreo
Jul 6, 2008 02:47 PM
classciv
16
Mar 7, 2005 08:46 AM
Project_EF
12
Feb 11, 2005 07:19 AM
geminis2k
Jan 24, 2003 11:22 AM
