91 civic b18b1 swap no injector pulse
Old Aug 23, 2012 | 06:07 PM
yzrider250's Avatar
Default 91 civic b18b1 swap no injector pulse
hey i have a 91 civic that had a dpfi obd0 motor in it. i put a b18b1 motor from a 94 integra with a 94 integra ecu. im using the 91 engine harness and i used this guide hondaswap.com/attachments/12192d1254934264-dxb18bwiring.pdf. i believe i did everything right. i have spark and fuel at the rail but the injectors will not pulse. i couldnt figure out how to repin the connectors so i just wired right into the obd0 to obd1 jumper harness. my grounds are good at the thermostat and i dont have the battery to tranny to frame ground because my battery is in the back. i dont have most of the vaccuum lines hooked up cause im just trying to fix the injector pulse. ive tried another ecu and no luck. i also just twisted the wires together so i could easily change something if i messed up. all you have to do is rewire the distibutor and make 2 wires for the other injectors right?
Old Aug 23, 2012 | 06:34 PM
Former User's Avatar
Default Re: 91 civic b18b1 swap no injector pulse
Is there battery voltage at all 4 injector clips?
Old Aug 24, 2012 | 07:14 AM
yzrider250's Avatar
I connected a test light to them and they didn't light up
Old Aug 24, 2012 | 07:43 AM
They get voltage from the Yel/Blk wire from the main relay (protected by 15A ECU fuse).
Old Aug 24, 2012 | 01:08 PM
yzrider250's Avatar
There's 3 yellow and black wires. two in the #3 socket and one in the #7. the one doesn't have power but the two do.
Old Aug 24, 2012 | 04:33 PM
Not sure what you're saying. What sockets are you talking about?
Old Aug 24, 2012 | 04:48 PM
crx_si-r's Avatar
I think he is talking about fuse box.
For the injector power source, use the yellow/black wires on driver shock tower
Old Aug 24, 2012 | 04:49 PM
crx_si-r's Avatar
Old Aug 24, 2012 | 04:51 PM
OP - post some clear pictures.
This^
It's terminal 8 in connector C313. Check for voltage there.
Old Aug 24, 2012 | 05:08 PM
Make sure to also test voltage at the Yel/Blk wire at the injector resistor.
Old Aug 24, 2012 | 06:30 PM
yzrider250's Avatar
It says I can't post attachments I was talking about the pins in the main relay there's 8 of them and 7 have wires going to them. And I don't have a resistor box.
Old Aug 24, 2012 | 06:45 PM
You can post pictures using PhotoBucket.
The main relay has two Yel/Blk wires. The one that runs to the fuel injectors pins to terminal 3 in the main relay connector. See diagrams below.
But start by testing voltage at terminal 8 (Yel/Blk wire) of connector C313. See post #9.
Old Aug 24, 2012 | 07:10 PM
yzrider250's Avatar
heres some pics http://s1205.photobucket.com/albums/bb439/speckit1994/
the one socket with two yellow and black wires have power but the one on the top with only one yellow and black wire dont have power.
Old Aug 24, 2012 | 07:24 PM
This^ is fine.
Now this:
Old Aug 25, 2012 | 10:18 AM
yzrider250's Avatar
I posted another pic on my photobucket. My drivers shock tower connector has more than 8 wires running to it
Old Aug 26, 2012 | 05:02 AM
yzrider250's Avatar
Anyone?
Old Aug 26, 2012 | 05:06 AM
Post the IMG codes of pictures into your post so that they display (see below). Check whether the wire color pattern in post #9 mostly fits the connector in your picture. Is there a Yel/Blk wire at the terminal 8 position. If so, check for voltage at terminal 8 on both the male and female sides of the connector pair.
Old Aug 26, 2012 | 05:16 AM
Well, after looking at the connector in your picture, it's a 14P not a 8P connector. Post pictures showing where this connector is located in your engine bay.
Old Aug 26, 2012 | 11:30 AM
yzrider250's Avatar
its on the drivers side shock tower i have the dx 91 civic not the si or whatever has the 8 pin
Old Aug 26, 2012 | 12:53 PM
Sorry, I should have thought of that. Below are your connector and its wire pin out.
The Yel/Blk wire at terminal 1 of C313 goes to the fuel injectors. Measure voltage there. FYI - The Yel/Blk wire at terminal 6 goes to the fuel pump.
Old Aug 26, 2012 | 04:55 PM
yzrider250's Avatar
i dont have power at 1 but i do at 6
Old Aug 26, 2012 | 05:00 PM
This^ is a problem. The Yel/Blk wire at terminal 1 of C313 runs to main relay connector terminal 3 (see post 12). Test the wire for continuity between these two points. The wire may be broken.
Old Aug 26, 2012 | 05:31 PM
yzrider250's Avatar
My Yel/Blk wire at terminal 1 of C313 runs to main relay connector terminal 7
i retested it and got a really weak light until my stupid *** grounded it and i lost all power to it. i checked all the fuses and there all good
Old Aug 26, 2012 | 05:57 PM
yzrider250's Avatar
this pic is how low the light is on the injector wire. i got it to get power
and this is how bright it usually is
do i need to run a resistor box on an obd1 94 integra b18b1?
i have saturated injectors but there too big the start the car with the stock tune. im currently using the stock ones w/o a resistor box. do i need one?
Old Aug 26, 2012 | 06:07 PM
This^ is correct for dpfi but not for mpfi, where the Yel/Blk wire at C313 terminal instead must pin to main relay terminal 3.
You have not made all needed wire changes for the dpfi to mpfi conversion.
