Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Grams Performance and Design / 550, 750, 1000cc Injectors / Best Honda Injector Out!
Old Aug 23, 2012 | 02:02 PM
importdps's Avatar
Default Grams Performance and Design / 550, 750, 1000cc Injectors / Best Honda Injector Out!
Import DPS is proud to announce we have just got our first batch of Grams Performance and Design Fuel Injectors on the shelves. These injectors have a quality that is unmatched by anything else on the market. We won't get into the entire sales pitch, its simply not needed. Watch the video and go over the details of each item. These Injectors all come with Pig Tailed Wire Clips and everything else needed to help aide your engine in getting the Fuel that it needs.
All Fuels can be used!!
*** Grams Performance and Design Injector Video ***
Click Here - > http://player.vimeo.com/video/47124607
Grams Performance is proud to offer the most innovative high-performance fuel injectors for today’s performance vehicles. Premium materials, advanced manufacturing techniques, and stringent quality control procedures make Grams Performance the leader in high-performance fuel injectors.
An engine’s fuel injectors perform a vital role in the accurate metering and atomization of fuel. Grams Performance accomplishes this with its high-impedance Bosch Motorsports EV14 fuel injectors that are modified for high-performance use. Each injector is individually balanced, flow tested, and dynamically matched for characterization within one percent of one another. To ensure leak-free operation and optimal performance, each injector is then pressure tested up to 220 psi. The results are unmatched cylinder-to-cylinder consistency, even at low pulse widths, as well as optimal idle quality, response, and performance. Grams Performance Fuel Injectors’ ultra-fast and precise solenoids feature a linear response curve across a wide range of operating conditions and can accurately meter fuel even at the highest pressures and shortest pulse widths.
The EV14 injector’s superior ball/pintle valves combined with Grams Performance’s precision-modified nozzles allow for consistent performance up to 118 psi, making them suitable for a wide range of applications, yet without exhibiting any of the high-pressure problems often associated with other injectors. The optimized spray pattern also helps improve mixture preparation as well as atomization.
Grams Performance injectors are cold-cut with diamond grinders in less than three seconds for high precision without “pre-seating.” Abrasive cutting creates heat, which leads to poor spray patterns and the need for competitors to pre-seat their injectors to reduce distortion. Each injector is also fitted with high-quality Viton O-rings that are resistant to extreme temperatures and harmful oils found in some fuels.
Each injector set includes dead time compensation values to help ensure consistent air/fuel ratios and optimal performance when tuning. Grams Performance Fuel Injectors are carefully tested and matched in controlled laboratory environments using state-of-the-art equipment and are subjected to rigorous dyno, street, and race track testing to ensure proper performance in the most extreme conditions.
High-impedance design (no resistor box required)
Cold-machined tips for high-precision operation
Ultra-fast solenoids for precise fuel metering
Linear response across wide range of operating conditions
All injectors balanced, blueprinted, and matched within one percent
Compatible with all known fuels including gasoline, methanol, and ethanol
Unmatched cylinder-to-cylinder consistency and optimal idle quality
*** Click Here to Order *** http://importdpsonline.com/grams_/gr...s/g-67541.aspx
We accept Visa, Mastercard, American Express and Discover Cards. Cash Pickups are always more than welcome in our Philadelphia Retail Store. All PA Residents are subject to 8% Sales Tax. Call us at 215-227-6000 should you have any questions. Injectors listed are for B-Series and K-series Honda. Buy the best!!
Thanks
Import DPS
www.importdpsonline.com
Old Aug 23, 2012 | 02:05 PM
importdps's Avatar
Default Re: Grams Performance and Design / 550, 750, 1000cc Injectors / Best Honda Injector O
Purchase the best injectors on the planet.
Old Aug 23, 2012 | 03:41 PM
importdps's Avatar
Bump for Grams Performance and Design Injectors!!
Old Aug 24, 2012 | 08:54 AM
importdps's Avatar
Bump!! Happy Friday
Old Aug 27, 2012 | 07:41 PM
importdps's Avatar
In Stock!! about to be Tuesday morning Bump!!!
thanks
Import DPS
Old Aug 28, 2012 | 06:31 AM
importdps's Avatar
Tuesday Grams Injector Bump!!!!
Old Sep 5, 2012 | 08:28 AM
importdps's Avatar
1000's are flying off the shelf!!
Old Sep 10, 2012 | 11:28 AM
importdps's Avatar
Monday Bump!!!!!
Old Sep 10, 2012 | 06:20 PM
importdps's Avatar
Monday Late Night Bump!!!
Old Sep 14, 2012 | 01:48 PM
importdps's Avatar
Friday Bump!! In Stock Parts at Import DPS!!
Old Sep 14, 2012 | 01:49 PM
importdps's Avatar
Video of a Kraftwerks Supercharged Civic Si using Gram's 1000cc Injectors.
importdps's Avatar
Another one, same setup.
Old Sep 17, 2012 | 07:42 AM
importdps's Avatar
In Stock Bump!!
Old Sep 18, 2012 | 06:41 AM
importdps's Avatar
Tuesday Bump!!!!
Old Sep 19, 2012 | 12:40 PM
importdps's Avatar
Weds Bump!!!!
Old Sep 21, 2012 | 08:14 AM
importdps's Avatar
Friday Bump!!!!
Old Sep 27, 2012 | 10:17 AM
importdps's Avatar
Bump!!!!!!
Old Sep 28, 2012 | 10:48 AM
importdps's Avatar
13 cars with Grams injectors over here. All running flawlessly. We expected that though.
Old Sep 29, 2012 | 08:49 AM
importdps's Avatar
Saturday Bump!!!!!
Old Oct 3, 2012 | 11:14 AM
importdps's Avatar
In Stock Injectors!
Old Oct 8, 2012 | 07:09 AM
importdps's Avatar
Monday Bump!!!
Old Oct 11, 2012 | 10:32 AM
importdps's Avatar
Bump!!!!! In Stock Parts
Old Oct 13, 2012 | 07:54 AM
importdps's Avatar
Saturday Bump!!!!
Old Oct 15, 2012 | 11:52 AM
importdps's Avatar
Monday Bump!!!!!!!
Old Oct 18, 2012 | 10:31 AM
LoSt is BlaCk's Avatar
They come in a neat black box rather than a generic "white box".
Here is what came in the box for my B-Series application. (4 injectors, adapters, pigtail harnesses, flow rate and dead time sheet, couple stickers)
The 550's come with some cool little gold badges on them. The other sizes they offer come with there own colored badges (red on the 750cc's and black on the 1000's)
The adapters so I can toss them into the my B-Series...
The flow rate and dead time sheet with the Grams Performance stickers that come in the box.
Afterwards I got a little time on the dyno, the tuner didn't have any problems with them and really liked having the dead times to use in my old tune. All in all the car seems pretty happy with them and the price was less than others on the market... so I'm a happy camper.
