Need .2 in the 1/4 in my EG
Old Oct 16, 2002 | 09:20 AM
nsxmatt's Avatar
Default Need .2 in the 1/4 in my EG
Next month i'm running the 1/4 for the last time this season. Chances are the last time for this setup..
92 VX hatch
Stock JDM B16 sir2/hydro tranny
AEM CAI
Greddy SP/no cat
DC 4-1
14" 205/55 Nitto DR's
On street tires not stripped in 90 degree heat it ran a 14.4 with a 9.3 @ 76 1/8th. Now in the 1/8th with DR's and stripped it runs 9.1's @ 78. So i'm guessing i'm at 14.2 now maybe better.
Everything from the front seats back will be stripped. Passenger side seat and Center console will be gone. Car has no a/c or PS. Wiper fluid res. is gone. Car still has stereo and two door speakers.
I want to run a 13.9 but i'm looking for a way to get another .2 out of the car without any more investment. I've done about everything I can, i'm just wondering if I missed something or if anyone has any ideas?
Old Oct 16, 2002 | 09:28 AM
SRT-WHORE's Avatar
Default Re: Need .2 in the 1/4 in my EG (nsxmatt)
You can try a lower tire pressure and that's no investment at all.
Old Oct 16, 2002 | 09:33 AM
NiiS's Avatar
Go on a diet...?
Old Oct 16, 2002 | 09:34 AM
vtecvoodoo's Avatar
Future Texas Boy
borrow slicks.
Old Oct 16, 2002 | 09:37 AM
JV's Avatar
JV
Who?
Default Re: Need .2 in the 1/4 in my EG (vtecvoodoo)
borrow slicks.
Old Oct 16, 2002 | 09:42 AM
nsxmatt's Avatar
Default Re: Need .2 in the 1/4 in my EG (JV)
I'm in the sticks of KY and the only honda actually running a DR so I doubt I can find a set of slicks to bolt on. I weigh 150lbs and the car is pretty much stripped. I could get another 20lbs maybe with some door panels and rear seatbelts but I'm not sure it would make up enough to go through with it.
Old Oct 16, 2002 | 09:44 AM
vtecvoodoo's Avatar
Future Texas Boy
borrow a zex or dry nos kit. They can be installed in less than an hour.
Ryan
Old Oct 16, 2002 | 10:21 AM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
advance your timing a bit....remove ps and ac if you havent already, jdm you prolly dont have it anyway...run higher octane petro
[Modified by CiRcUiTsi, 11:22 AM 10/16/2002]
Old Oct 16, 2002 | 10:23 AM
DevinW's Avatar
If your track allows it, try running with an open header. That may give you a bit better time...
Old Oct 16, 2002 | 10:51 AM
nsxmatt's Avatar
Default Re: Need .2 in the 1/4 in my EG (DevinW)
The track is about 2 hours away so I most likely will leave the exhaust hooked up since it will be too cold to get under the car to drop it. I would do a Zex but I wanted to see if I could do 13's on a stock all motor B16 w/bolt-on's. I may get a light and advance the timing a bit.
Old Oct 16, 2002 | 11:12 AM
DevinW's Avatar
Those are some sweet times by the way...good drivin'!
You could try some more weight reduction...airbags and cpu, if any...firewall mat, sound deadening, carpet, headliner. Borrow a friends 1 piece racing seat...they are about half the weight of a regular seat.
You could also bring a toolset to the track and take off the bumper supports, etc before you race. Not a good idea to drive on the street without these though.
Good luck dude!
Old Oct 16, 2002 | 11:30 AM
sammysnakes's Avatar
when you get to the track unbolt the cat from the header, move the cat to the side and rebolt the left side of the cat to the right side of the header. it only takes a few minutes.
Old Oct 16, 2002 | 11:40 AM
Archidictus's Avatar
Unceasing Measure
Default Re: Need .2 in the 1/4 in my EG (chainsaw)
just testing an image for somebody
[img]http%3A%2F%2Fwww.imagestation.com%2Fpicture%2Fsrai d35%2Fp3caa6bd63e9371517534975ad38aaab8%2Ffd2d39ad .jpg[/img]
Old Oct 16, 2002 | 11:41 AM
Evs-One's Avatar
Solbros Owns Me
You should be there by gutting it, take out head unit. Run as leats gas as possible too
Old Oct 16, 2002 | 11:48 AM
MPower332TI's Avatar
Default Re: Need .2 in the 1/4 in my EG (Emerica)
hey dude are you racing ur car at beech bend in bowling green????? we race up there sometimes..i havent been since ive put the motor in my car so id like to go...when are you going???? my friend troy has a b16 in a stripped 92 cx and he ran a 14.3 with just an intake and exhaust.(focker) anyways id take out the rear bumber support, the door panels,etc...also go to the track on empty and put some of there race gas in it..about a gallon should do..then just nail those 60ft times..let me know when u plan on going to the track..im sure it would be on a saturday night right?? ill bring the crew..
Old Oct 16, 2002 | 12:06 PM
Slopoke's Avatar
Default Re: Need .2 in the 1/4 in my EG (jDmDxTuRd)
Unbolt your exhaust and remove your rear bumper support and cover.
Old Oct 16, 2002 | 12:10 PM
nwdave's Avatar
Default Re: Need .2 in the 1/4 in my EG (Slopoke)
Good luck with the 13s
Old Oct 16, 2002 | 12:34 PM
civura R's Avatar
Default Re: Need .2 in the 1/4 in my EG (delsolguy)
practice ur take offs and 60 foots a 9.1 1/8 mil e is pretty good
try and hook up a dryey hose to ur intake and run it to the front of the car
out ur headlight or bottom of teh bumper . id unbolt the exaust a lil also in the back u dont even have to jack ur car up
good luck
Old Oct 16, 2002 | 12:50 PM
nsxmatt's Avatar
Default Re: Need .2 in the 1/4 in my EG (civura R)
I'll take off the rear muffler, forgot about doing that. Plus it will be alot easier Tank is always close to empty when I run.
I can work on my 60ft time though. My best has been 2.111 on nitto drag radials and I know I can get a 2.0 out of em on a good track. And yes i'm running at Beech bend in Bowling Green. We plan on going Nov. 9th I believe so if you plan on going let me know. Who was the guy in the cx? It wasn't Darksubrosa was it?
Old Oct 16, 2002 | 12:53 PM
DOMKID's Avatar
remove front and back bumper. try to get 2.0 60 ft.
Old Oct 16, 2002 | 12:56 PM
underrated99si's Avatar
Default Re: Need .2 in the 1/4 in my EG (Dominican_Kid)
Drink a bottle of X-lax and take a huge **** before you run should drop atleast 5 or 6 pounds. OR take all the sound materail off the (aka tar) on the floor of the car.
Old Oct 16, 2002 | 03:50 PM
nsxmatt's Avatar
Default Re: Need .2 in the 1/4 in my EG (underrated99si)
I'll take the tar out over taking a hour long squirt festival. Especially since I have nothing to read
Old Oct 16, 2002 | 03:56 PM
eg_nezay's Avatar
Get some 20x8x14 slicks and get a 1.8?? 60ft
Old Oct 16, 2002 | 04:16 PM
nsxmatt's Avatar
Default Re: Need .2 in the 1/4 in my EG (eg_nezay)
It took me a long time to find some drag radials so it's gonna be a while before I get some slicks.
Old Oct 16, 2002 | 05:00 PM
eg_nezay's Avatar
Ill sale u mine wit steelies on them for 100bucks! I got five lug now , so I dont need the 4 lug ones anymore.They got me 1.8s most of the time
