Car hesitate to start at first
Old Aug 23, 2012 | 03:51 AM
AccordBoy88's Avatar
Default Car hesitate to start at first
so i just bought a 2001 integra ls auto and it hesitates to start at first but my 3rd or 4th time it starts up perfectly i just change the fuel filter and spark plugs and im still having problems.
car drives fine but cant seem start the car the first time and it happen when i leave the sitting more then 10min
and when i do get to start the first time it look like it want to shut off but doesn't. and goes back to idling normal
Old Aug 23, 2012 | 04:21 AM
el crapitan's Avatar
Default Re: Car hesitate to start at first
install a fuel pressure gauge. see if the system holds residual pressure. residual line pressure should drop no more than 1psi per 30seconds. and to a maximum complete drop of 15psi
if pressure bleeds off any more than that, likely the fuel pump will need to be changed
Old Aug 23, 2012 | 04:25 AM
try cycling the key on for 5 seconds right before you start. if the car starts right away, you know its a residual pressure issue
delsol92
Feb 25, 2012 04:27 AM
rgondzur
Honda Civic (2001 - 2005)
Apr 25, 2011 09:04 PM
Jos3ph
Oct 19, 2008 12:09 PM
crexer
Jun 8, 2003 07:51 PM
