1990 honda accord wont restart when its hot
Old Aug 22, 2012 | 07:23 PM
bluejay's Avatar
Default 1990 honda accord wont restart when its hot
my 1990 body but 1993 engine honda accord wont restart mostly on hot days. or after i have had the air conditioner on. when this happens i have to wait between 5 to 10 miniutes for it to start, i have been told its the ignition relay.
does anybody have any info on this issue?
i was told the sauter on the connection melts when the car is hot then i have to wait for it to coagulate before it will start ,
i dont know where this relay is or how difficult it is to change, or if this is really the problem,,
need help
thanks bluejay
Old Aug 23, 2012 | 12:26 PM
badcb7's Avatar
Default Re: 1990 honda accord wont restart when its hot
It's most likely the main relay. It's located under your dash on the driver side and if you have cruise control you gotta remove the cruise control computer. Once you have it out you don't have to buy a new one. If you have a soldering iron you can open it up and look for hairline breaks or cracks in the solder. If you find some then just heat them up so it reforms and you can install it back and it should fix your problem! Good luck!
Old Aug 23, 2012 | 10:41 PM
bluejay's Avatar
thanks for the tip, i,ll post the results in about a week when i have the time to go after it.
thanks again
bluejay
Old Aug 24, 2012 | 07:27 PM
nus_dogg's Avatar
X2 on the main relay.
poindex75
Aug 7, 2009 08:19 AM
failed2live
Jun 26, 2009 03:13 AM
toys4red
May 22, 2008 03:57 PM
alwaystheking43
Jul 5, 2007 10:48 AM
s_sandwichh
Apr 25, 2006 06:33 PM
