92 INTEGRA SOLENOID PURGE VALVE
ok, the original one has 2 power and 2 grounds 1 pos , the other just has 1 pos and 1 ground, should i join the 2 pos wires to the 1 pos wire and the same goes to the grounds?
The one you're showing for the Acura doesn't look right at all. It looks like something off some '96+vehicle. Are you sure that's an EVAP Purge Control Solenoid? Remember that '96+ EVAP systems have a number of solenoids.
The Civic one should work fine.
Either your solenoid in question is NOT the EVAP Purge Solenoid, or you're running some kind of setup that's been altered from stock.
qntmfzx
Jun 13, 2009 02:20 PM
Hockey27925
Sep 19, 2007 08:21 PM
FLCivic
Oct 23, 2005 01:39 PM
ACURAS
