Using 56.6mm Center Bore Wheels on our 56.1mm Civic?
Old Aug 22, 2012 | 06:15 PM
hmong337's Avatar
Default Using 56.6mm Center Bore Wheels on our 56.1mm Civic?
Will I have any issues? Looking to pick up a set of winter tires off a Daewoo Lanos... those use a 56.6mm center bore. Our Civics run a 56.1mm center bore. Will I be fine?
Old Aug 22, 2012 | 06:19 PM
jbpnoman's Avatar
Default Re: Using 56.6mm Center Bore Wheels on our 56.1mm Civic?
IIRC, Civics are lug centric, not hub centric, so you should be fine as long as you use the proper lug nuts.
KadenEF
May 6, 2017 11:41 PM
l2aymond_23
Apr 1, 2013 04:41 AM
dderolph
Jan 4, 2013 04:36 PM
Nicram
Oct 17, 2005 08:12 PM
Aron Parsons
May 21, 2003 08:51 AM
