Transmission & Drivetrain Gearboxes, Differentials, Clutches
H22A EG Shifting Problem
Old Aug 22, 2012 | 03:20 PM
KillinEm18's Avatar
Icon6 H22A EG Shifting Problem
I have a 93 EG Coupe with an H22A swap in it. It doesnt shift into 3rd, feels like its hitting a rubber wall or somthing, maybe it is binding. Any ideas of what this could possibly be?
Old Aug 22, 2012 | 03:34 PM
MR.johnson's Avatar
Default Re: H22A EG Shifting Problem
what condition is the linkage in? bushings and cables...
Old Aug 22, 2012 | 03:57 PM
KillinEm18's Avatar
they dont appear to be in bad condition shifter isnt loose or anything just wont push into 3rd
Old Aug 23, 2012 | 01:20 PM
extralargenog's Avatar
I dont think its the cables. Has the trans been apart?
Old Aug 23, 2012 | 01:22 PM
Easyu way to check, undo the cables from the trans and shift it. Thyll bind if theres an issue. Also while theyre off try to shift the trans without them hooked up. My money says internal or if its been apart, the detent ball spring is hammering the fork because the spacing washer is hammered
Old Aug 23, 2012 | 02:29 PM
KillinEm18's Avatar
actually did this early this morning, and its not the cables, think it is internal, but will the detent ball make it feel like pressing against rubber? i dnt know if its been apart or not, i just got it a week ago.
Old Aug 23, 2012 | 02:30 PM
COuld be that, a broken blocking ring stuck or bent fork
Old Aug 23, 2012 | 02:33 PM
KillinEm18's Avatar
ok. thanks for the ideas man, im gonna look into it
KillinEm18
Aug 23, 2012 06:52 AM
pcguy760
Apr 18, 2007 10:08 PM
spidersam
Mar 12, 2007 02:19 AM
pane93civhb
Apr 26, 2005 10:21 AM
