Advice on 53 plate EP3 CTR
I need some technical advice and guidence on how or what to replace as i have some DTC Codes in the check engine light is on the dash..
P0108 (3) Manifold Absolute Pressure (MAP) sensor high input.
P0113 (10) Intake Air Temperature (IAT) sensor circuit high input.
P0325 Knock Sensor Circuit Malfunction.
p1298 Electrical load detector circuit high input.
these are the codes showing on a scan.
where can i locate or how do i replace what ever is causing these fault codes to appear?
Please help a new and inexperienced Type R owner. Hope i haven't bought a wrong en!
Fix P1298 and see what happens. Replace the ELD in the Fusebox. It will take care of the P1298 code.
Part number: 38255-S5A-003
Got mine here: $21.18 plus shipping
http://www.hondaautomotiveparts.com/...VIN+Number+---
Here's a how to from EPhatch.com
http://www.ephatch.com/forum/showthr...ighlight=p1298
Here's the TSB pdf from Honda, this will also tell you how to do in detail:
http://www.ephatch.com/forum/showthr...l=1#post892154
Good luck!
Good luck!
irishgreen4
Aug 29, 2012 06:00 PM
