Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
AEM Electronics Exclusive SALE Buy one get something FREE!
Old Aug 22, 2012 | 09:42 AM
Sales@Bisimoto.com's Avatar
Icon3 AEM Electronics Exclusive SALE Buy one get something FREE!
Buy any AEM EMS-4 and get a FREE Serial Gauge Kit Only $759.99 with FREE SHIPPING!
That's right... Free Serial Gauge!
Call today to place your order!
888-922-6686 or email Sales@Bisimoto.com
AEM's EMS-4 Universal Standalone Programmable Engine Management System (part# 30-6905) is the ideal standalone Engine Management System for modified Powersports and four-cylinder race car applications. The EMS-4 was created using AEM's powerful Series 2 hardware and includes all of its advanced features without the unneeded ancillary components. Free shipping world wide!
WHY YOU WANT THIS
If you have modified your four-cylinder Powersports application beyond the factory ECU's ability to control engine operation, or have a 4-cylinder race vehicle that does not require some of the advanced hardware features of an AEM Series 2 Plug & Play System, AEM's EMS-4 provides complete engine control for the maximum power and reliability.
THE HARDWARE
AEM's EMS-4 provides complete engine control for small engines with up to 4 cylinders. The unit includes a 36-pin connetor that is specifically designed to operate in harsh environments. It is completely sealed and weather/shock proof, allowing it to be mounted anywhere. The EMS-4 works with MAG or HALL crank inputs and can directly drive smart coils or an external ignitor such as AEM's 4-Channel Coil Driver (part # 30-2840).
KEY FEATURES
4 Saturated Injector Drivers
4 Coil Triggers
8 General Purpose Inputs/Outputs
Mag or Hall Cam and Crank Inputs
O2 Input
Knock Input
8 MB Internal Data Logger
VSS Hall Input
Can Data Stream
USB Comm Port
Compact (4.8" x 4.55" x 1.44"), weather/shock proof enclosure
Utilizes AEMTuner Interface Software
System is fully enabled and unlocked - Never pay for Upgrades
Context Sensitive Help Eases Tuning Process
Maps can be Password Protected by the Tuner to Prevent Unauthorized Usage Sharing
Buy any Series 2 EMS and get a FREE Serial Gauge Kit!
SERIES 2 KEY FEATURES
- Plugs directly into the factory harness. No rewiring necessary.
- Uses all the factory sensors.
- Includes start up calibrations.
- System is fully enabled and unlocked - Never pay for upgrades!
- Context sensitive help eases tuning process.
- Maps can be password protected by the tuner to prevent unauthorized -usage or sharing.
- Runs on Windows-compatible software.
- 8 direct-fire coil outputs.
- 16 general-purpose outputs.
- 8 definable switch inputs.
- 4 EGT inputs with fuel control.
- 1MB of internal data logging.
- Electronic boost control.
- Full idle control.
- Programmable traction control.
- Software definable knock control.
- Two step launch control.
- User configurable soft-cut rev limiters.
- Wet or dry nitrous control.
- Tune using new USB communication port or serial port.
- Works with all AEM gauges.
AEM’s Serial Gauge
Plugs into our Series2 or Series 1 EMS giving you the ability to read up to 19 channels simultaniously. Now you can read boost, AFR, EGT, H20 Temp, IAT, RPM MPH and more on one gauge with an easy to read, digital LED interface. You can link multiple Serial Gauges together to divide your reading across several gauges.
Buy any AEM Water/Methanol Injection Kit and get a FREE AEM Inline Filter!
WHY YOU WANT AN AEM WATER/METH KIT
AEM’s Water / Methanol Injection Kit reduces air inlet temperatures and exhaust-gas temperatures, which allows you to increase boost pressure and advance timing without having to run higher-octane fuel. It’s like getting to run 100+ octane gas for the price of Premium!
WHY YOU WANT OURS
AEM’s Water / Methanol Injection Kit includes all the features necessary to do water/methanol injection right. No hidden costs or optional components are required. Unlike other popular kits on the market, we include a one- or five-gallon tank with a fluid level sensor standard. Also, because we think engine protection is a requirement, not an option, we include our Boost Safe output in every controller we design. This feature allows you to retard timing or reduce boost if the system runs out of fluid or detects an error. With the AEM Water / Methanol Injection Kit, you get all the best features in one low priced kit.
The AEM Water/Methanol Injection Filter
An in-line filter that uses a micronic mesh screen to filter particulates as small as 40 microns. This allows a cleaner flow of water/methanol to be passed into the engine, not only protecting the internals of the engine itself, but also the working parts of the water/methanol pump, too. Run the AEM Water/Methanol Injection Filter in-line before the pump to protect both pump and engine.
Buy any FIVE of these Widebands and get a FREE replacement sensor.
Call today to place your order!!!
Whether you have a mildly upgraded setup, or a full all out build, monitoring air fuel ratios (AFR) is a great way to make sure that your setup is performing at peak efficiency. It can also provide your aftermarket ECU with a constant data steam, allowing for closed loop oxygen sensor feedback, so that the ECU can "self adjust" for elevation, atmospheric and load changes on the fly.
Bisimoto endorses the "easy to install" AEM wideband UEGO system, and it is on sale now with free shipping within the continental USA!
Buy any FIVE of these Wideband Kits:
30-4100 Digital Wideband Gauge
30-4900 Wideband Failsafe Gauge
Get this FREE
30-2001 Bosch LSU 4.2 Wideband UEGO "Replacement" Sensor.
KEY FEATURES
- No free air calibration required - ever
- Accurate to .1 AFR
- Adjustable backlighting via a dial on the back of the gauge
- Two status lights for error detection and operating status
- Includes white and black gauge faces
- Includes black and silver interchangeable bezels
- 320 degree viewing area for unsurpassed resolution
- Includes Bosch 4.2 sensor for optimum accuracy and reliability
- 0-5v analog output included for use with data loggers and virtually any engine management system
- Reads Gasoline values from 8.5 to 18:1 AFR
- Reads E85 values from 5.7 to 12:1 AFR
- Reads Ethanol values from 5.2 to 11:1 AFR
- Reads Methanol values from 3.7 to 7.8: AFR
- Reads Lambda values from 0.58 to 1.22 AFR
Old Aug 22, 2012 | 10:49 AM
Julio@Bisimoto's Avatar
Default Re: AEM Electronics Exclusive SALE Buy one get something FREE!
Got some great deals today! Shoot me a PM!
Old Aug 22, 2012 | 01:08 PM
Special ends August 31, all AEM pricing starting October will go up in pricing. Don't miss out on this sale!
Old Aug 22, 2012 | 03:56 PM
Thank you for your orders.
Old Aug 22, 2012 | 04:21 PM
Janet@bisimoto's Avatar
Please call today to place an order: *888-922-6686 or check out via www.bisimoto.com. Mention Honda-Tech for a free Bisimoto License Plate holder and Bisimoto Goodies. (*Retail Value: $16.99)
Old Aug 23, 2012 | 08:34 AM
Old Aug 24, 2012 | 10:54 AM
Hurry-in...
Sale END's August 31st 2012
Old Aug 24, 2012 | 02:59 PM
Hurry-in...
Old Aug 24, 2012 | 04:34 PM
SALE ENDS AUGUST 31's
Old Aug 27, 2012 | 10:26 AM
Call in today at 888-922-6686 or email Sales@Bisimoto.com for this special limited offer!
Old Aug 29, 2012 | 08:35 AM
Exclusive Special For All Honda-Tech Members!!!
Old Aug 30, 2012 | 10:31 AM
Bump! For great specials!!!
*888-922-6686*
Old Aug 31, 2012 | 08:37 AM
It's Friday!!!!
Take advantage of these specials!!! Offer still available....
Old Sep 7, 2012 | 11:05 AM
Purple-skunk's Avatar
AEM wideband \.
How much shipped to 20740??
Thanks
Old Sep 7, 2012 | 01:35 PM
Originally Posted by Purple-skunk
AEM wideband \.
Thanks
Give me a call today for accurate pricing. In stock ready to ship!
Old Sep 7, 2012 | 04:11 PM
Thank you everyone for the orders! We appreciate your support!!!
Have a great weekend!!!!
Old Sep 19, 2012 | 10:16 AM
Offer has Expired! Call today as we are continuing running great specials!!!
Inquire today: *888-922-6686 or email sales@bisimoto.com
Old Sep 20, 2012 | 09:49 AM
*888-922-6686*
Old Sep 21, 2012 | 10:54 AM
Thank you everyone for the orders. We appreciate your support!
Old Sep 24, 2012 | 09:20 AM
Give us a call today... New Pricing!!!
*888-922-6686
Secure these specials today!
Old Sep 25, 2012 | 12:30 PM
We look forward to assisting you with your performance goals!!!
Kindly give us a call when you are ready to proceed with your selection!!!!
*888-922-6686
Old Sep 26, 2012 | 12:52 PM
Call-in for the best deals!
*888-922-686
Old Sep 28, 2012 | 09:23 AM
Please call today to place an order: *888-922-6686 or check out via www.bisimoto.com. Mention Honda-Tech for a free Bisimoto License Plate holder. (*Retail Value: $16.99)
Old Oct 3, 2012 | 10:37 AM
Old Oct 5, 2012 | 08:07 AM
TGIF!!!!
CALL Today to place your order!
*888-922-6686
