shaking steering wheel!!!
Old Oct 16, 2002 | 08:35 AM
95redcivicex's Avatar
Default shaking steering wheel!!!
well this is driving me insane and i cant explain it. when ever my d16z6 is below 1000 rpms the steering wheel shakes and the dash vibrates alittle. I could live with it but id rather fix it. Anyone have experience with this because im stumped.
Old Oct 16, 2002 | 08:44 AM
Default Re: shaking steering wheel!!! (95redcivicex)
ttt
Old Oct 16, 2002 | 08:56 AM
mrxroe's Avatar
if it was a manual i would tell you to take off at a higher rpm or easier on the clutch. since its prolly an auto just get a new torque converter.
Old Oct 16, 2002 | 09:38 AM
neveronlines2k's Avatar
Default Re: shaking steering wheel!!! (mrxroe)
Check your motor mounts and the timing. How low is the idle? Mine shakes a little when the engine is cold and is a little louder then normal, but soon as the car warms up it goes away. You might just need a tune up/valve adjustment. My freinds car was vibrating way more then usuall after he got a valve adjustment it cleared up. Good luck finding out whats causing that. I would try checking some of the things I talked about and seee if that doesn't help the situation.
Old Oct 16, 2002 | 09:44 AM
cre18's Avatar
Default Re: shaking steering wheel!!! (stuckatworksi)
are your tire lugs all torqued the same?
Old Oct 16, 2002 | 10:15 AM
TheIntegraGuy's Avatar
Default Re: shaking steering wheel!!! (cre18)
alignment?
Old Oct 16, 2002 | 12:04 PM
jdmsol's Avatar
Default Re: shaking steering wheel!!! (SiDESLiDE240)
alignment?
yeah!
Old Oct 16, 2002 | 12:06 PM
flip b18b's Avatar
Default Re: shaking steering wheel!!! (jdmsol)
i know this might sound stupid have you checked the air pressure in ya front tires? also have you had then balanced lately?
[Modified by hondafreakc5, 9:06 PM 10/16/2002]
Old Oct 16, 2002 | 12:07 PM
nwdave's Avatar
This is when you're just stopped, idling...right?
This has happened to me too, in both automatic and manual Hondas. It's just the low idle that's causing your steering wheel to shake.
Old Oct 16, 2002 | 07:59 PM
Default Re: shaking steering wheel!!! (delsolguy)
This is idling so im not moving. It shakes anywhere below 1000 rpms. So its at a pretty high idle. You might be onto something with valve adjustment. Anyone else.
Old Oct 16, 2002 | 08:21 PM
DevilSolSi's Avatar
i have the same problem while my car is idling....i need to get a valve adjustment anyway so im hopin that will fix it....i checked all the mounts and theyare fine so im not too sure
Herbie
31
May 13, 2015 06:34 PM
raverx3m
Nov 24, 2010 04:11 PM
jim109
Jan 21, 2007 09:26 AM
Turbo Squid
Aug 15, 2005 07:08 PM
jerm001
16
Mar 4, 2005 09:21 AM
