gear removal
Old Aug 21, 2012 | 07:00 PM
shaggyrufener's Avatar
Default gear removal
i cannot remove timing gear from crankshaft , 1997 accura integra non- v-tec can anyone please help? i have already broke 2 pullers. thank you
Old Aug 21, 2012 | 07:44 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: gear removal
try spraying it with some pb blaster, then get two pry bars on each side and work it each corner one at a time or wiggle each corner simultaneously and work it off the crank shaft. I did this method with the motor in the car.
Old Aug 21, 2012 | 07:54 PM
el crapitan's Avatar
you shouldn't need to use a puller.it isn't press fit.
try shocking it. that is, tap the crank snout with a brass hammer while prying the gear
preludeNApower
Dec 4, 2012 05:52 PM
SIXTY-1HATCH
Sep 13, 2006 08:43 AM
david90
Sep 29, 2003 03:15 AM
H22AJSPEC
Jul 16, 2003 07:38 PM
