b18 swap not starting with key
B18a1 first was okay when i installed it
after a while it was occasionaly not starting using the key, i would have to jump starter signal to straight power wire on the starter to get it to start.
So far i have
Cleaned the battery conections
checed fuse box conections clean and tight
Checked starter fuse - not blown
checked 50 amp ignition fuse - not blown
put a new ground from starter to firewall cleaned ground
still not starting......
Do you think this could be my starter the power wire inside not getting a signal to where it needs to?
Do i need a new starter?
i wanna figure it out before thursday because i am getting alignment and tires mounted and balanced i really dont want to be charged 20 dollars labor just for them to start my car. any help greatly appreciated.....
Thanks
So far i have
still not starting......Do you think this could be my starter the power wire inside not getting a signal to where it needs to?
Thanks
Have you checked to see if the starter wire is giving 12v when you are turning the key to the start position?
when you try and start it is it just dead? Do you get a click sound or anything like that?
I would check the ignition switch to ensure it is functioning properly.
Check this website on how to do this.
http://mycomputerninja.com/~jon/IgnitionSwitch.html
Okay, i put a new starter in and it is working. i just didnt wanna spend the money to get a new one for it not to fix my problem.
I cleaned the ignition now i am getting 12 volts to the signal wire as well
Thanks
Thanks
Schultzie
Jan 23, 2013 09:46 PM
ahem ahem
Aug 23, 2009 06:28 PM
