My New Suspension Setup Arrives (pics)
Old Oct 16, 2002 | 08:21 AM
Flux's Avatar
Default My New Suspension Setup Arrives (pics)
Received my new TODA Racing FIGHTEX FS coilovers today from AKH Trading. These are very high quality pieces and I'm looking forward to getting them on my car. I know not many people ahve these coilovers at all, so I will be sure to post extensive reviews. Let's please not turn this into a discussion about "Why didn't you get Zeal/Buddy club?" or "You paid to much."
Spring rates will be 10k/8k.
I will post more pics, weight, and impressions later - I just wanted to get the first pictures up.
Question about installation: I was all geared up and ready to install these myself using some how-to guides and you guys on H-T as resources. Most of the guides talk about installation of coilovers as a single pre-assembles unit. These coilovers have arrived not as a single piece and I will need to install the springs, helper springs, upper pillow ball mounts, etc. Is this going to make installation much more difficult? Will I need a spring compressor?
Old Oct 16, 2002 | 08:25 AM
Cosworth's Avatar
Default Re: My New Suspension Setup Arrives (Flux)
YOu probably won't need a spring compressor... unless you're going for a 4x4 look.
If for some reason you need to use a spring compressor, the best way is to take your suspension setup to a tireshop and use their wall-mounted industry use spring compressor. It only take a minute w/ these things and they will only charge you either or $20 tops.
Old Oct 16, 2002 | 08:27 AM
yoshi234's Avatar
I shoot brides
Nicey nice!!!
well, j00 shouldn't need a spring compressor, unless those new sus require parts off the old sus (which I don't think it does).
The fronts will be a little bit harder than rears, but the install should be pretty straight forward.
One thing I suggest is to take careful measurements of the spring height and keep a record of it.
Old Oct 16, 2002 | 08:29 AM
Hooch'n's Avatar
Default Re: My New Suspension Setup Arrives (yoshi234)
.....enjoy
Old Oct 16, 2002 | 08:30 AM
Reid's Avatar
Global Moderator
I recommend using the 10k springs in the rear.
Also you *might* want to rethink using upper pillowball mounts on a street car.
No remote reservoirs?
Old Oct 16, 2002 | 08:32 AM
GM2000ITR's Avatar
New User
How Much?
Old Oct 16, 2002 | 08:40 AM
Money Hou$e's Avatar
Very nice, looking forward to your review.
Type-R Yo!'s Avatar
New User
All I have to say is Sweet man
Old Oct 16, 2002 | 08:41 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Default Re: My New Suspension Setup Arrives (Reid)
Very nice suspension. Congrats on the new toy!
When you put the pillow mount together, MAKE SURE you put in the pieces in correct order. I've heard dramatic difference in suspension performance if pillow mount is not installed correctly, even if it's as small as a washer or a nut.
Old Oct 16, 2002 | 08:43 AM
Flux's Avatar
Default Re: My New Suspension Setup Arrives (Wai)
What is that correct order? I cannot read the Japanese instructions...
Old Oct 16, 2002 | 08:44 AM
Smitdog's Avatar
b
Old Oct 16, 2002 | 08:48 AM
Wai's Avatar
Wai
No diagrams? I put together a set of TEIN RS with my friend. It had helper springs and pillow upper mount. The instruction shows what nut goes first and which washer goes on top etc etc. Upper mount from each manufacturer is different so it really depends on what the instruction says.......
Old Oct 16, 2002 | 08:59 AM
yoshi234's Avatar
I shoot brides
j00 should know by now to send me a copy or put up da pix and i'll translate
Old Oct 16, 2002 | 09:09 AM
Rob Dizzle's Avatar
that will be a nice setup
If you dont have a spring compressor (im sure you dont have)
I usually go to a local auto shop and they are willing to help me out by assembling the spring/strut combo
or you can buy basic ones for under 50 bucks, then loan them to friends or whatever when they need them
Old Oct 16, 2002 | 09:12 AM
zer0zer0 TypeR's Avatar
yea the stock rubber ones won't cut with such a nice expensive setup
Old Oct 16, 2002 | 09:14 AM
EleanoR's Avatar
Default Re: My New Suspension Setup Arrives ('00TypeR)
Damn those things are sweet
Old Oct 16, 2002 | 09:40 AM
Dirty GS-R's Avatar
New User
Default Re: My New Suspension Setup Arrives (EleanoR)
......:drool:
Old Oct 16, 2002 | 09:44 AM
GokuSSJ4's Avatar
Default Re: My New Suspension Setup Arrives (Cosworth)
you shouldnt have too , Teins come the same way and i doont recall on the install using a spring compressor
Old Oct 16, 2002 | 09:53 AM
Willard's Avatar
oh my.... all of the kittens..
Old Oct 16, 2002 | 10:37 AM
disordeR's Avatar
Default Re: My New Suspension Setup Arrives (Willard)
very nice. i was lookin for the remote resevoirs like the pic on the box. lookin foward to the review.
i just looked on the todaracing.com site. are there anymore specs on the FS coilovers then what's stated? full aluminum.. you should weigh each coilover! we should get coil over weights like wheel weights...
[Modified by disordeR, 11:45 AM 10/16/2002]
Old Oct 16, 2002 | 10:40 AM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: My New Suspension Setup Arrives (disordeR)
nice
Old Oct 16, 2002 | 10:43 AM
Ricky Rojales's Avatar
*speechless*
Old Oct 16, 2002 | 11:06 AM
Kengs's Avatar
Default Re: My New Suspension Setup Arrives (P)
Very nice Jonathan
Those sure do look a lot like Quantum RS series coilovers (looking at the shock bodies)
Old Oct 16, 2002 | 11:10 AM
BlueR's Avatar
Default Re: My New Suspension Setup Arrives (VTEC VX)
my eyes are "red" with envy
Old Oct 16, 2002 | 11:16 AM
Flux's Avatar
Default Re: My New Suspension Setup Arrives (BlueR)
Thanks guys
I just need to figure out how to assemble the coilovers correctly (I've never done this before).
