92' EG B20 Swap
Looking to swap a B20 into my eg and need any info or a redirect to an old thread that might help me and guide me through this swap, itll be my first swap project so any info will be greatly appreciated, thanks guys.
Easy plug and Play. Use stock mounts (u do need integra rear t bracket), stock wire harness, b20 ecu, b series shift linkage, teggy manual axles and half shaft( assuming 5spd), that is about it. Drops right in. All sensor plugs that are on b20 would be on any stock sohc non/v wire harness with few left over not used
The injectors, alternator and distributor aren't plug and play, you'll either need some adapters or use their OBD1 B18B counterpart. But it might help to list your year/make/model/trim of your Civic. Also what B20 is it? B20B? B20Z?
