Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Rebuilt Trans - Sometimes no third/fourth - No reverse
Old Aug 21, 2012 | 05:29 AM
rdcd12's Avatar
Default Rebuilt Trans - Sometimes no third/fourth - No reverse
Hoping someone can help shed some light on this. Recently rebuilt the BXMA trans with new clutches, steel, all new orings/gaskets, and a reman torque converter.
Put the trans in and immediately we had no reverse. At first we had no third or fourth gear, but a few times it would show up and engage fully. In the process of taking the trans back out and inspecting it to see if we can find where we went wrong, but was hoping someone might be able to shed some light on this.
Did everything according tot he book, purchased the right tools for the job and took no shortcuts whatsoever. All new Honda fluid when case was resealed.
Old Aug 21, 2012 | 06:39 AM
Nitrous1024's Avatar
Default Re: Rebuilt Trans - Sometimes no third/fourth - No reverse
Are you sure that your "shift" solenoids are good and are working properly?
Old Aug 22, 2012 | 09:22 AM
rdcd12's Avatar
Thanks for replying. They def were. We ended up figuring it out. For some reason when ever we bolted the main case on the counter shaft would become super tight and not move at all. Luckily we had another trans with parts around.
We swapped the counter shafts and voila... no more resistance. Put it back in and she's behaving exactly as you would expect after the overhaul service. We didn't replace the case bearings though and am wondering what the stance is on that.
Old Aug 23, 2012 | 06:09 PM
It Wasn't Me's Avatar
Why not?!?!?! You already had the thing apart!!
Old Aug 24, 2012 | 03:51 AM
rdcd12's Avatar
Figured, was just asking. It's all a learn in progress and the next time I already know what to order and have ready.
Old Aug 24, 2012 | 09:41 AM
Figured, was just asking. It's all a learning process and the next time I already know what to order and have ready.
Hopefully the bearings survive until the next rebuild.
Old Aug 24, 2012 | 01:56 PM
rdcd12's Avatar
Play on words.
TSEF22
12
Jun 10, 2021 01:11 PM
Combatlouie
Transmission & Drivetrain
Nov 19, 2013 06:20 PM
tomstock202
Dec 3, 2008 07:46 PM
a6killa
Jan 19, 2008 06:34 PM
