Suspension & Brakes Theory, alignment, spring rates....
Brakes and Idle
Old Aug 21, 2012 | 02:14 AM
hfraziers's Avatar
Default Brakes and Idle
When my brake is un-pressed my car idles ~1.3k. If I press the brake it drops to 750.
Any ideas?
Obviously it's vacuum but I don't know how to find out where. Any ideas about where?
91 Integra converted to Non-ABS.
Old Aug 21, 2012 | 05:43 AM
Dontoh's Avatar
Default Re: Brakes and Idle
most shops can smoke test for vacuum leaks.. if you look around online, you may be able to find a vacuum diagram for your set up, then go and check everything
Old Aug 21, 2012 | 11:48 AM
hfraziers's Avatar
I have to diagnose myself. Do they use a smoke machine?
How would you test vacuum?
Unfortunately before I put my motor in my car I put a Hondata Intake Manifold gasket on it. Do these symptoms line up with IM leak? Is it possible a leak at my brake booster causes this?
Hoping the wisdom of the masses will save me.
Old Aug 21, 2012 | 06:05 PM
grumblemarc's Avatar
The Grumpiest
Why don't you get some carb cleaner and start spraying everywhere there could possible be a vacuum leak with the engine running? Worrying about an intake manifold is unproductive and just a random guess which defies all troubleshooting steps.
Old Aug 21, 2012 | 06:46 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Hmm, I never gave it much thought but my rpm's raise when I hit the brake. I will have to check it out when I get home.
Old Aug 24, 2012 | 09:19 AM
hfraziers's Avatar
Thank you I shall. I suppose I'll be looking for bubbles? Haven't done this before.
Old Aug 24, 2012 | 09:32 AM
No the carb cleaner will cause your motor to rev if it is able to leak into the manifold.
DUKE LADUKE
25
May 10, 2011 09:21 AM
4g4dcruisin
Jan 6, 2010 07:33 AM
z28matt
Dec 17, 2009 09:22 PM
TheCrimsonGhost666
Mar 26, 2009 01:40 PM
category5 SI
May 30, 2007 04:06 PM
