why doesnt my car blow air at all?
I have a 95 accord ex and I was using the regular air with no ac on and speed setting 2 all of a sudden it stops blowing I try all speeds nothing what could it be everything else in the climate cont works besides blowing air??
It's most likely a bad blower motor or bad resistor. First, look under the passenger side dash for the blower motor assembly. You can't miss it, it has a round casing. Unplug the connector. It'll be a 2 wire connector. Jump battery positive to 1 wire and ground to the other. Either wire works as it'll spin both ways. It's kinda hard to run jumper wires all the way from the battery so, I use a cordless drill battery. If it doesn't run then it's like 3 screws to replace it. If the blower motor runs when you jump it then it's good and we need to look at the resistor: Turn the A/C on and measure for voltage at both those wires. If there's no voltage then replace the resistor, which should be right next to the blower motor assembly
b.gaines
Jul 18, 2016 06:41 PM
SMcCoyEX
Honda Civic (2001 - 2005)
Mar 4, 2016 07:30 PM
