Fully built and sleeved b18c1 golden eagle
Got this off a buddy of a buddy of mine and now decided to go back to school.
ZERO MILES, ALL DOCUMENTATION, bottom built by GE, head done by justice racing engines.
$4250 plus shipping
B18C1 serial# 8303286
HEAD
Complete Ferrea valvetrain kit:
CompPlus oversized valves
Endurance Valve Springs
Spring seats
Ti Retainers
Billet valve locks
Valve stem seals
Competition P&P
5 angle valve job
GSR cams
Silver valve cover Freshly powder coated with -10an fittings installed
Cylinder faces/ chambers modded for 84mm bore
All new bolts, studs, washers, and nuts for intake and exhaust manifolds
BLOCK
84.5mm bore
Golden eagle sleeves
CP 9.0:1 pistons
Eagle H-beam rods
arp bolts
ACL Bearings (Main, Rod)
ACL thrust washers
Fully balanced and blueprinted
Rev Match to 10,000 rpm
Hot tanked etc.
Moroso oil pan
Moroso oil pickup
AEBS pro spec head studs
Cometic head gasket
New Seals
Gap rings
Toda timing belt
Type R pumps
$4250 plus shipping
HEAD
Spring seats
Ti Retainers
Billet valve locks
Valve stem seals
Competition P&P
5 angle valve job
GSR cams
BLOCK
84.5mm bore
CP 9.0:1 pistons
Eagle H-beam rods
arp bolts
ACL thrust washers
Hot tanked etc.
Moroso oil pan
Moroso oil pickup
Cometic head gasket
New Seals
Gap rings
Toda timing belt
Type R pumps
i got a b18c1 that i built up the shop messes it up and iam burning oil i was going to just rebuild the block but for everything i need is going to cost me quiet a bit how much would you take if i traded you my engine plus cash for yours and i can probably pick it up but it wont be till the end of janurary
HEAD
skunk2 pro 2 cams and valvetrain
buddy club camgears
stock valves
supertech valve stem seals
arp head studs
BLOCK
11.9:1 supertech pistons 81mm
eagle h beam rod
acl bearings
stock crank
HEAD
buddy club camgears
stock valves
arp head studs
BLOCK
eagle h beam rod
acl bearings
stock crank
$2250 for the head and $2750 for the block, labor on the head alone was almost $2000
price do not include shipping
located in arizona
