Low alternator voltage on 2000 civic dx
Old Aug 20, 2012 | 02:06 PM
Yoitshector's Avatar
Default Low alternator voltage on 2000 civic dx
So I was getting low voltage from my alternator so I replaced it an I'm still getting 12.46 volts on idle and no higher than 12.6 when engine is running. Changed alternator fuse and belt. Anyone have any other suggestions? Also new battery as well
Old Aug 20, 2012 | 04:59 PM
Former User's Avatar
Default Re: Low alternator voltage on 2000 civic dx
Check fuse 15.
Old Aug 20, 2012 | 08:03 PM
Did that already. Still the same?
Old Aug 20, 2012 | 08:25 PM
When you turn the key from off to ON(II) (engine off), does the charging system light (battery symbol) turb on and stay on?
Old Aug 20, 2012 | 10:14 PM
No battery symbol at all.
Old Aug 21, 2012 | 05:09 AM
That's a problem. Fuse 15 is probably blown. Don't replace it. Instead measure voltage on both top tabs of the installed fuse. Click the Fuses link in my signature.
Old Aug 21, 2012 | 06:25 AM
I tested both tabs of the fuse with a test light both tabs lit up but I will redo with a multimeter
Old Aug 21, 2012 | 06:56 AM
Check whether the charging system bulb socket and the 4P alternator plug get voltage from fuse 15.
If the voltage regulator in the alternator does not get voltage from fuse 15, the alternator will not charge the battery.
Old Aug 21, 2012 | 07:18 AM
How would I do what you stated above
Old Aug 21, 2012 | 05:21 PM
Bump
Old Aug 21, 2012 | 05:31 PM
Unplug 4P alternator connector and turn key to ON(II). Measure voltage to body ground at the Blk/Yel wire terminal.
Old Aug 21, 2012 | 11:44 PM
Okay so I did that and I'm getting 12.25 volts.
Old Aug 22, 2012 | 05:36 AM
Check whether the charging system bulb is blown.
Old Aug 22, 2012 | 06:08 AM
It's not. Light turns on in on position (II), and turns off when car is turned on.
Old Aug 22, 2012 | 08:20 AM
Old Aug 22, 2012 | 08:33 AM
My apology let me clarify this. The battery light turns on, in the on (II) position, and turns off when engine is running. I didn't read that through carefully and thought you had asked if the light turns on when the car is running.
Old Aug 22, 2012 | 09:40 AM
There's a large white wire that runs from the alternator to the hood fuse box. Turn key off. Disconnect the battery connectors and the white wire from the alternator. Measure the resistance (Ohms) between the + battery connector and the alternator end of the white wire.
Old Aug 22, 2012 | 10:01 AM
I disconnected the wires from the battery and alternatora wire from the fuse box and I get two numbers the first is 2.62 and than the multimeter says o.l than 28.95 pops up
Old Aug 22, 2012 | 10:07 AM
And that keeps being repeated with the same numbers
Old Aug 22, 2012 | 03:41 PM
It's unclear to me that you did the test I suggested.
Old Aug 22, 2012 | 09:20 PM
? I set the multimeter to ohms and touched on probe to the pOsitive wire and one probe to the white alternator wire coming from the fuse box
Old Aug 22, 2012 | 09:37 PM
What did you disconnect?
Old Aug 22, 2012 | 10:46 PM
+ and - battery wires and the white alternator wire from the fuse box.
Old Aug 23, 2012 | 02:11 AM
Ok so I redid it right now at work and got the number 2.099 pictures are attached of the wires disconnected what wires I touched the two probes with and of my multimeter so you can correct the way I'm doing if it is wrong. Thank you for yOur patience and help btw.
Old Aug 23, 2012 | 02:27 AM
Images are
1: numbers that multimeter shows
2: multimeter probe connected to te positive wire
3: second multimeter probe connected to the alternator wire
4: showing the alternator wire I disconnected
5: showing the battery wires are disconnected
