how to un-turbo a gsr??
Old Aug 20, 2012 | 07:28 AM
purple_civic94's Avatar
Default how to un-turbo a gsr??
i boughbt a 95 gsr boosted with 1000cc injectors, chipped ecu, and it was dyno tuned.
i want to go back to all motor for winter but i dont know what i need to go back to a reliable natural aspirated gsr
any input would be greatly appreciated!!
Old Aug 20, 2012 | 08:51 AM
racebum's Avatar
Default Re: how to un-turbo a gsr??
if the motor is stock you will need
1. obd1 240cc injectors
2. p72-a01 ecu or a gsr map burned on your ecu
3. a header
if the motor is not stock you will need the same as above except you will have to have another tune done and chip burned for your ecu
the easiest thing you can do is buy a smaller wastegate spring and leave the car as is. you can set the boost lower and give you less power with nothing more than a spring change.
DA STRIKER
Feb 4, 2011 03:49 PM
wildcard69
May 5, 2005 08:47 AM
B20zvtecek
Mar 12, 2002 05:27 PM
