Auto door lock in 2010 Si?
I have used the search to find this but come short. I haven't been on the site for years (old member with over 5k posts). Could someone tell me if there is a combination to cancel the child lock on my doors? I have a 2010 FA5 sedan. I hate having to unlock the doors for passengers in the rear.
No, sorry I will clarify. When the car reaches like 10mph the doors auto lock. When I turn the car off and get out all of the doors stay locked until someone in the front seat presses unlock for the entire car. There must be a way to turn this feature off.
Auto or manual?
That's weird... mine unlock as soon as I turn the car off. I think there is a way to change that. I'll see if I can find it.
EDIT** Found this on the interwebz. From what I read on that site you h have to disable the unlock feature so all the doors unlock? I don't know, it read like VCR instructions.
Also, it's supposed to be in your manual if you have one.
Steps to set Auto-Unlock modes on.
The auto-door unlocking feature has two or three possible settings, depending on transmission.
These modes are:
Door unlocks whenever you turn the ignition to LOCK (0) position.
On Automatic transmissions, the driver's door unlocks when you move the shift lever to the PARK (P) position.
The auto-lock is deactivated all the time (factory default.)
To unlock the driver's door on automatic vehicles when the ignition switch is out of the ON (II) position.
1) Make sure the shift lever is in PARK (P), and close the driver's door.
2) Turn the ignition switch to the ON (II) position.
3) Set the parking brake.
4) Push and hold the brake pedal, then move the shift lever out of PARK (P).
5) Push and hold the rear of the master door lock switch on the driver's door. You will hear a clicking sound, and after about 5 seconds, you will hear another clicking sound.
6) Release the switch, move the shift lever to Park (P), and turn the ignition switch to the LOCK (0) position within 5 seconds.
To unlock the driver's door on manual vehicles when the ignition switch is out of the ON (II) position.
1) Close the driver's door.
4) Push and hold the rear of the master door lock switch on the driver's door. You will hear a clicking sound, and after about 5 seconds, you will hear another clicking sound.
5) Release the switch, and turn the ignition switch to the LOCK (0) position within 5 seconds.
To unlock the driver's door when shifted into "Park" position. (Automatic Only)
1) Make sure shift lever is in PARK (P), and close the driver's door.
Disabling Door Lock Modes, both Automatic and Manual
1) Open the drivers door. [On Vehicles with automatic transmission, make sure the shift lever is in PARK (P).]
2) Turn the ignition switch to the ON [II] position.
4) Push and hold the front of the master door lock switch on the driver's door. You will hear a clicking sound, and after about 5 seconds, you will hear another clicking sound.
Disabling Door Unlock Modes, both Automatic and Manual
* All settings of the Door Locks will retain setting even if the battery is disconnected.
These modes are:
