fs: 91' hatchback
FS: 91 ef Clean title – asking $1500
Jdm D15b with 2nd stage crower cam w/ str cam gear, the motor is completely healthy I've put bout 30k miles since I got it. Does not burn any oil at all, no leaks **** is as mint as it gets! Comes with short ram carb legal intake, no name headers, ngk wires new rack & pinion, straight pipe only has resonator buyer can compression test it before purchase. It is wired OBD1 done by R1 motorsports in rosemead/san gabriel.
Si cable trans only slight grind in high 3rd shifts. I've been running the magnetic plugs on the pan and the trans which romoved most of the shavings from the trans. Comes with auto virgin p28.
Si seats front and rear.
Da front spindles with rear disc conversion.
kyb shocks/skunk2 coilovers
Body is straight with slight damage to passenger fender and hood is not original one has some dents.
I have an extra ef9 rear bumper in white that I will throw in since previous owner drilled the holes on the original one.
Car needs tags they were due last July 16th, should be at $120 plus smog. It needs some paint, a new windshield, and a clutch it's beginning to slip plus the throwout bearing can be heard grinding. tires are still good for another 15k miles, just had a front alignment at bear about 1 month ago. Overall the car just needs some TLC I can no longer have time for or room so that's the reason for selling. I have the pink slip in hand so hmu with the cash! 626 416 8725 call/txt serious buyers only... price is pretty low already for what's in it. located in baldwin park, ca
