HELP!!!SHAKING MOVING IN FIRST GEAR
Old Aug 19, 2012 | 04:56 PM
95EG2's Avatar
Default HELP!!!SHAKING MOVING IN FIRST GEAR
I HAVE 95 CIVIC W/ H2B... I HAD PUT MY MOTOR IN BEGINING OF LAST YEAR WITH OEM EXEDY CLUTCH AND F1 RACING FLYWHEEL(BOTH WHERE 1 YEAR OLD AND CAME OUT OF MY B SERIES SWAP)...BUT LIKE A MONTH AGO MY CAR STARTED TO SHAKING WHEN TAKING OFF IN 1ST GEAR...I KNEW IT WAS MY PASS. SIDE AXLE SO I REPLACED MY CLUTCH WITH A COMPETION CLUTCH STAGE 4 AND A NEW AXLE... BUT MY CAR STILL HAS A SMALL SHAKE TAKING OFF IN FIRST GEAR, NOT AS BAD AS B4 BUT IT STILL THERE...B4 U CAN FEEL IT FROM THE PASSENGER SIDE NOW U CAN FEEL IT FROM THE DRIVER SIDE BUT THE AXLE IS A YEAR OLD... ANY IDEA
Old Aug 19, 2012 | 05:31 PM
upnsmoke's Avatar
Default Re: HELP!!!SHAKING MOVING IN FIRST GEAR
Does the chatter occur only when you are slipping the clutch, or after the clutch is completely out as well? I had a kevlar clutch that chattered while being slipped on light acceleration.
Old Aug 19, 2012 | 06:40 PM
Mr. Dabolina's Avatar
If thats a puck clutch youre going to get some shuddering. Theyre not really designed to be eased out. Theyre designed to bite hard and quick.
Otherwise start checking mounts for stripped bolts and broken rubber. Give the front suspension a good once over while youre down there.
Old Aug 19, 2012 | 06:43 PM
Dontoh's Avatar
is it possible that the damaged passenger axle caused premature wear on the drivers axle?
Old Aug 19, 2012 | 06:56 PM
95EG2's Avatar
im gonna drive it tomorrow only drove it a couple times but if i ease off the clutch and accelerate lightly no chatter at all...
plus i had this problem b4 i put the clutch in
Old Aug 19, 2012 | 07:06 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
I have a shake when I am hard on the throttle in 2nd and 3rd of my gsr swap so I am curious to what is causing this... I was thinking it might be the clutch but it only happens at mid rpms. Everything else on my front suspension is new and hasport mounts. I am thinking if it is my clutch I won't worry about it because i will be upgrading in a few months when I go boosted.
Old Aug 20, 2012 | 02:52 AM
coooljmp's Avatar
What kind of axle did you use? I say put a drivers one in too. I only ask what kind you use cause I've had new "rebuilt" axles from FEQ brand vibrate and shake on a VW I was working on. So don't always trust "rebuilt". Just my opinion.
Old Aug 20, 2012 | 04:24 PM
95EG2's Avatar
i drove it today it vibrates during acceleration 1st thru 4th gear... but i was looking and it looks like i have a bad bearing on the itermediate shaft... going to look at it this week
Old Aug 20, 2012 | 08:56 PM
HMM never thought about that since my swap had less than 80k. Have to check that when I get home in a few weeks.
Old Aug 23, 2012 | 02:41 PM
95EG2's Avatar
replace my driver side axle and it was just as bad as the passenger side, but no luck still does the same thing... i hate to think it the competetion clutch i just put in b/c it was doing it b4 i put it in... anyone help i hate throwing parts at it
Old Aug 23, 2012 | 03:36 PM
95EG2's Avatar
car has a rough idel and when i push the clutch pedal in it goes away. i have the trans out replace the flywheel and getting the trans check out... anyone have any idea while i have the trans out
Old Aug 26, 2012 | 03:10 PM
95EG2's Avatar
Old May 6, 2013 | 07:08 PM
colin8811's Avatar
Any update on this?
Old May 10, 2013 | 01:52 PM
95EG2's Avatar
After replacing everything... Innovative motor mounts 2 different pair of brand new axle from auto zone, new flywheel and intermediate shaft... I gave up and sold the swap... I belief that it has a defective competition clutch I hasn't puting any more
Money into the swap to find out
Old May 10, 2013 | 03:46 PM
ReaperMan's Avatar
what h2b kit did you have qsd or evolution? me and the homie were having the same problem ended up being a cheap clutch sometimes gears would go in hard where did you buy this competition clutch from? what brand? did you check the flywheel for hot spots? we had hot spots on our flywheel from a cheap clutch that was not promised to do into the swap they charged us for a exedy clutch but it was a cheap Chinese knock off cost like $70 after research and on top of that we took the tranny for inspection and guess what fucked up gears and sleeves along with hubs no wonder gears would go in hard all do to a cheap clutch
buymesomedunks
Jul 13, 2013 10:30 PM
ElectronBlue00
21
Feb 9, 2013 03:35 AM
klystron59
Apr 25, 2010 04:56 PM
jxhxb
Oct 8, 2009 09:55 PM
BlueRex1020
Sep 24, 2006 03:56 PM
