Pictures needed of how the harness go's over the hump inside the car
I have a 96 teg and I need a picture of how the main wiring harness go's across the hump in the center..I cant figer out how it needs to be routed. there is this plastic thing on it that looks lilks like it gets bolted down somewhere. I can post pictures.
Pics would help.
This may or may not help... http://www.acuraautomotiveparts.org/...s=&view=normal 94
The "plastic" piece gets mounted behind the pedals, and the loomed part goes over the hump.
Should be 3 10mm bolts holding it on which you'll see underneath if you have the black padded mat taken out.
Now I cant figure out how the fuse box under the dash mounts. Anyone have pix?
adrenaline_nsx
Audio / Security / Video
Feb 5, 2010 01:31 PM
