99 ls integra type r swap help
Old Aug 19, 2012 | 03:01 AM
aaron_drifter's Avatar
Default 99 ls integra type r swap help
Ok so I am going to be doing a type r swap into my 99 ls integra within a month or two and need some help. The swap of the engines is pretty strait forward my question is which wires will I need to add. I will be using the engine harness that comes with the car but am in sure if there is any additional wiring that needs done and if so does anyone have pics or info on this. And is there any other issues that I may run into? Exhaust parts fitting or anything else.
Thanks
Old Aug 19, 2012 | 08:01 AM
ohiobornDC2's Avatar
Default Re: 99 ls integra type r swap help
you will need to add the wires for vtec and a couple other wires....just google the info and you can find everything online ie wiring diagrams and everything
Old Aug 19, 2012 | 08:41 AM
I have done some digging on google and haven't found much but will look some more thanks bud
Old Aug 19, 2012 | 09:34 AM
HondaPartsHero's Avatar
Technical Hero
Add VTEC solenoid, VTEC pressure switch and knock sensor wiring from the sensors to the ECU. Most everything else will plug and play wiring wise.
Old Aug 19, 2012 | 10:49 AM
You sir are awesome. Thanks a bunch
ungers_21
Jun 10, 2008 07:08 PM
