Apexi VAFC question
Old Oct 16, 2002 | 06:01 AM
ejectseat's Avatar
Default Apexi VAFC question
hey - you guys who installed apexi vtec controllers, can you hit vtec when you rev in neutral or when your car is cold? thanks
Old Oct 16, 2002 | 06:18 AM
aklucsarits's Avatar
New User
Default Re: Apexi VAFC question (ejectseat)
VTEC actuation is land-speed dependant. There is a minium engine load and vehicle speed that must be achieved before it activates. The Apexi VAFC does not change that.
Of course you would never want to rev your car that high when it's cold anyway, as you could cause severe engine damage.
Andrew
Old Oct 16, 2002 | 06:34 AM
Sittin in my Sparcos's Avatar
Default Re: Apexi VAFC question (aklucsarits)
there is a cold rev limiter at 6500 when the car is cold or in neutral....its a safety feature
Old Oct 16, 2002 | 04:33 PM
ejectseat's Avatar
WELL, i recently wired a field sfc and vtec changeover is dependent on RPM'S only. The only wire I had trouble w/ was the vtm, and when I hooked it up CORRECTLY my car threw check engine lights. Disconnected the vtm and it was fine. does vtm have anything to do w/ oil pressure or engine temp?
Old Oct 16, 2002 | 04:59 PM
the VTM wire is the ECU's signal to the vtec solenoid in the engine.......the engine needs certain parameters, like certain rpm, oil pressure and temperature, throttle position etc, before it sends the signal thru the VTM wire to the engine.
You shouldn't get a CE light if all the wires are done up correctly....I hooked my VAFC myself and have no probs at all
_Endless_
Jun 26, 2003 03:57 AM
B18Redline
May 27, 2003 10:07 AM
94jdmsol
Jan 8, 2003 08:48 PM
wildesh
Dec 6, 2002 07:18 PM
