Stock Fenders with 225/45/15 slicks?
Old Aug 18, 2012 | 07:46 AM
kueda's Avatar
Default Stock Fenders with 225/45/15 slicks?
Hey Honda tech,
I was just wondering if anyone know's if 225/45/15 slicks will fit on my Type R without fender modifications? My car is pretty low... Anyone running 225's without rubbing issues?
Thanks
By kueda at 2012-08-18
Old Aug 18, 2012 | 10:15 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Default Re: Stock Fenders with 225/45/15 slicks?
What kind of slicks?
There's no problem running 225/50-15 or 225/45-15 in the front of the DC2. But in the back it would slightly rub the trailing arm depending on the offset of the wheels.
Old Aug 18, 2012 | 11:00 AM
kueda's Avatar
The wheels are SSR Type C 15x7 +42
Tires are Continental GT Slick Take Offs similar to Hoosier R6's.
If I through a 5mm spacer on in the rear would it be ok?
Old Aug 18, 2012 | 11:21 AM
highroller54's Avatar
I dont see the point of 225's on 7" wheels
Old Aug 18, 2012 | 11:39 AM
kueda's Avatar
Tires are used so no choice in the size. 2-3 heat cycles. Seller claims around 75% tire left.
I though 225's still fit ok on a 7" wheel? Would that be too much stretch for slicks?
Old Aug 19, 2012 | 10:45 AM
Wai's Avatar
Wai
225/50 is a perfect fit on a 7", while 7.5" is most ideal for 225/45. But 225/45 can still be mounted on 7" with no problem. You can check the spec sheet for your specific tire. It should show a range of wheel width.
Old Aug 19, 2012 | 10:47 AM
Wai's Avatar
Wai
You really need to test fit. But 225 is a lot of tire for the rear, and with spacers to clear (wider track), you might suffer massive understeer.
Old Aug 21, 2012 | 06:52 PM
freshCROOKS's Avatar
how much did u get those wheels for? some kid said he picked his up for around $400. i thought its was fairly cheap so i been bugging him to sell it to me.
Old Aug 22, 2012 | 07:07 AM
kueda's Avatar
That kid either has Rota's or he got a hell of a deal!
I got a contact in Japan to buy them for me off of Yahoo Auction Japan. These are JDM SSR Type C's not the USDM version.
I believe they sold for close to $750usd at auction. After handling fee's and shipping they were around $950 landed.
Old Aug 22, 2012 | 08:22 PM
[QUOTE=Wai;47750999]??
QUOTE]
LOL, in my world 225= 15x8, I stick with 205's on 7's
Old Aug 23, 2012 | 05:43 AM
AFTERZERO's Avatar
I run 225/45/15s continental slicks on my itr. 15x8s rota slips 40 offset. Fronts fenders have a slight roll where the fender liner clips into and the rears have a slight roll. No spacers, no rubbing anywhere. I do run pretty aggressive camber though.
Old Aug 26, 2012 | 12:42 PM
George Knighton's Avatar
H-T Order of Merit
15x7 +38 Type C's will hold 225-45-15 RA1 just fine. There's a lot of 225-45's that are too wide, but the RA1 works. You sort of have to look at the published measurements of the exact tyre series.
totsie7944
Nov 5, 2009 10:31 PM
Tad
23
Jun 26, 2007 10:15 AM
blackstar
Jan 1, 2007 08:34 PM
Chris Sawatsky
11
Oct 18, 2005 10:46 AM
Todd00
Jan 21, 2002 04:36 AM
