97 Ex Sedan B20B Swap...
Old Aug 17, 2012 | 04:58 PM
nightscream's Avatar
Default 97 Ex Sedan B20B Swap...
So because of some overtime at work... I decided to do a B20B swap in my 97 Civic Ex Sedan!!! I'm doing this swap mainly "just because" but I want all the benefit's of a B20B bolted to a B16 trans. has to offer in STOCK TRIM. Mountain's, ton's of stop light's, and running the AC on a wore out SOHC is getting on my nerves!!!
PART'S LIST:
99 JDM B20B (147hp)
99-00 Civic Si Trans., axles, half-shaft, shift linkage, 2 post motor mount
94-01 Integra Flywheel, LS Intake Manifold, Fuel Rail
94-95 Integra OBD1 ECU (already had the conversion harness)
98 CR-V "P7J" AC Bracket
ON ORDER:
Exedy Stage 1 Clutch Kit (just ordered)
ARP Pressure Plate & Flywheel bolts (just ordered)
CompleteTiming Belt Kit (just ordered)
Gonna use my 97 Ex wiring harness, and a B series torque mount for the trans.
***So my real question is!!!! Will the OEM Exhaust Manifold on the B20 match up to the STOCK EXHAUST at the cat on my civic??? The importer where I bought my motor said it would!!! Really need a DEFINITE ANSWER on this!!!!***
Old Aug 17, 2012 | 05:47 PM
turbohatch96y7's Avatar
Default Re: 97 Ex Sedan B20B Swap...
Who cares if it doesn't get your piping either shortened or extended. 20 bux and its fixed.
Old Aug 18, 2012 | 09:54 AM
Why did you even post in my thread if you don't have a REAL ANSWER to my question!!! And some people do care!!!
Old Aug 18, 2012 | 10:02 AM
200 people viewed and no replieed I'm pretty sure no one cares if you have an extended stock exhaust system
Old Aug 19, 2012 | 05:07 AM
Whatever dude... you should just hang yourself!!!!!!!!!!
Old Aug 19, 2012 | 06:07 AM
grumblemarc's Avatar
The Grumpiest
How hard would it be to take it to a shop if it doesn't? Not very. His answer was legit and the importer already gave you an answer before you even posted this.
Or you could have done a simple Google search like I did.
https://www.google.com/search?q=b20b...w=1598&bih=901
Old Aug 19, 2012 | 06:19 PM
I understand his answer is legit... BUT You know as I do half the answer's on here & over the internet are WRONG. I REALLY would like not to have to go that route!!! I can't be the only person on this site that want's what I want!!! I understand there has been over 200 people that have looked at this thread & not answered but maybe they just settled for going to the muffler shop and spending money to cut & weld their exhaust... The one's that go the extra mile get the cleaner set ups!!!
And by the way I do search maybe I don't key in the right phrase to turn up the info you posted but I do search.
viperboyjj
18
Jul 17, 2008 12:35 AM
97EXCivicCP
Mar 18, 2006 09:22 PM
88crxsison
Sep 7, 2005 07:52 PM
thingsiwouldsay
Jan 20, 2002 10:51 AM
