93 Del Sol S/JDM D15B Vtec - battery drain and overheating problems
I'll start with the first problem i'm having..
I while back I re-wired my aux light switch on the dash so that they would come on with the low beams and high beams. Their was a full wright up on it that I followed. That worked great and I have never had a problem with it... Until I installed my EDM aux lights. What i did was just cut the sensor off the old aux lights and wired the H4 sensor up to them. I've noticed that ever since i did this, Something has been draining my battery EXTREMELY quick. Where I can only start it about 3 times before i have to jump it off again. Is it possible that the new aux lights are drawing power even when they're not on if the switch is still pressed in?
The second problem is... I noticed yesterday that my car was running hot on the way to work. It got to operating tempurature very fast, and when i came to stops at red lights, the needle would go up about 3/4 of the way, almost to HOT. I parked the car and popped the hood, i noticed while i was driving, it was fine, but once i parked, the needle climbed and the fan would kick on, but once it stopped it would climb again.
Is it possible that these 2 problems would be related? I have so far replaced my starter, gone through 2 batteries and 2 alternators, the water pump and everything was replaced before i put the new motor in about 5 months back. brand new thermostat as well.
If you can help me out with any of this, i would really appreciate it. It's really killing me not being able to have my car function correctly.
BTW: this is in a 93 Del Sol S with a JDM D15B Vtec.
2. Do a pressure test to find leaks, I had no leaks in my car at all, the reservoir was full, and it ended up being a faulty radiator cap after i tested that.
on a sidenote, what is that in your grill that seems to be holding up your front lip?? it has me dazed and confused
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
Taylor Lanier
May 5, 2017 11:44 AM
srt4pilot
Feb 22, 2013 01:12 PM
explosive
Oct 11, 2004 02:28 PM
