D15B7 Issues
I just installed a D15B7 into my '00 hatch because I needed my car running ASAP. I'm using the obd2 engine harness, my D16Y7 fuel rail and injectors along with my distributor as well. The car starts up and idles a little low but when I hit the gas it has late response then shuts off if I go over 2k RPM. Does anyone know what it could be?
Did you reuse the y7 intake and exhaust manifolds?
Check codes without a reader
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Also the B7 doesn't have a CKF sensor by the crank you'll have to bypass
http://technet.ff-squad.com/ckftrick.htm
@Strategy400 I'ma go get one then and see what's up then since this ****'s driving me nuts lol.
@HondaPartsHero Thanks man I'll use that list if anything and I didn't know about the CKF, I'll definitely give that a try and see what happens.
writemealetter
Aug 27, 2017 12:26 PM
Nyceguy17
Jun 11, 2005 02:49 PM
