Random Technology Catalytic for Acura Integra 96-01
Old Aug 17, 2012 | 02:49 PM
DynamicCK's Avatar
Default Random Technology Catalytic for Acura Integra 96-01
BRAND NEW High Flow Catalytic for Acura Integra 96-01 DC2, fit GSR but not Type-R - $200. should be cheapest around.
Bought it for my Civic that I was building but bought the wrong one.
BRAND NEW, if you need to pass smog, this should do it.
Located in Orange County, we can meet up or I can ship to you if you pay the shipping, should be $20.00
Product Description
Since 1993 SuperStainless catalytic converters from Random Technology have been setting the standard for high flow high efficiency catalytic converters. Over the years improvements in chemistry and metallurgy have enabled Random Tech to continually upgrade catalytic converter performance and durability. As a result SuperStainess converters with either metal matrix or ceramic cores continue to be the best catalytic converters available. Independent testing by engine builders racers and automotive magazines has repeatedly proven the superiority of the Random Technology SuperStainless design. See the "test results" page for actual dyno test data. This design which meets Federal EPA and California ARB requirements enables virtually any vehicle with a properly tuned engine to meet emissions standards with little if any power loss (compared to an exhaust with no catalytic converter). Please note that it is illegal to remove a properly functioning catalytic converter and that aftermarket catalytic converters are not legal for installation in California on OBD II vehicles (some 1994 & 1995 and all 1996 and later vehicles). In fact Random Technology high efficiency catalytic converters actually have a higher flow capacity than many mufflers. As an example a 3" diameter 7000 series SuperStainless catalytic converter flows 617 cfm. Most 3" diameter high performance mufflers flow less than 475 cfm at the same test pressure. Random Technology direct fit SuperStainless catalytic converters are available for most domestic and imported vehicles. Custom catalytic converters with inlets and outlets up to 5" in diameter are available. Random Technololgy also offers metal matrix catalytic converters designed for maximum flow capacity. These high flow converters are designed specifically for use in sanctioned race classes that require the use of catalytic converters.
Old Aug 28, 2012 | 05:38 AM
DynamicCK's Avatar
Default Re: Random Technology Catalytic for Acura Integra 96-01
bump!
Old Nov 3, 2012 | 12:43 PM
DynamicCK's Avatar
BUMP
DC_Chick
Sep 4, 2011 11:25 AM
wardseg6
Jan 26, 2007 03:57 PM
Andrew 825SM
Apr 18, 2004 10:54 AM
