H22a1, Prelude Parts, and Misc
Old Aug 17, 2012 | 01:46 PM
Luded93's Avatar
Default H22a1, Prelude Parts, and Misc
I am selling a bunch of stuff from a project car. Most of the stuff is for the 92-96 Preludes or the 93-95 H22a1. I am trying to go back to school and will accept any reasonanle offers (mostly because I do not even know what to ask for on most of this stuff). If you want more pictures or a part I mentioned is not pictured, let me know (Also, I through this together kind of fast and the pictures are not great). Feel free to PM me with any and all questions or offers, and please bump.
Thanks Guys.
Some Of the prices are negotiable, so feel free to give a fair offer. Here we go...
1. H22a1 Head, fully build and ported and polished by JG. The head comes with a polished and port matched intake manifold, a polished and port matched throttle body, and a reprogrammed ECU. The head was acquired from a friend and has no more than 700 miles on it. Since then, i have had the head fully disassembled, cleaned, and checked from a local machine shop. I will include anything that is needed that originally went with the head (Cams, caps,...). $950.00 for everything
2. An H22a1 block that was used on an all motor build. It has JE Pistons 10:1 pistons, Eagle H-beam rods, completely rebalanced crank, and new cast iron sleeves. The block, since built, also only had a few hundred miles on it before i tore it down. Since then, it has been disassembled, checked, has new piston rings, all new bearings, and a fresh honing. Also, it comes with new rear main seal, new ARP studs, new oil pump, oil pan, and new oil pan gasket. $750.00 for everything
3. JDM black one piece headlights. $225
4. Skunk2 Cam Gears (Brand New) $170.00
5. AEM Cam Gears (Used) SOLD
6. AEM Aluminum Pulleys (Used) SOLD
7. I have a polished AEM CAI that is polished and has some signs of wear, mostly in places where the the car caused it. SOLD
8. Forbidden Motorsports true short shifter (Brand New)
9. WeaponR fuel Pressure Regulator with gauge $35.00
10. Autometer gauges and dual pillar. The gauges are all 2 1/6 mechanical, sport compact boost, oil pressure, and air/fuel (All Brand New) $125.00 for all
11. OEM Tweeter Covers with fog light switch. $85.00
12. 2 Nexen CP461 205/50/15 tires with 100% tread. $70.00
13. OEM Floor Mats in decent condition. $25.00
14. MSD sport compact ignition (Brand New) SOLD
15. Brembo Cross drilled and slotted OEM size front rotors and Bradt slotted rear rotors (brand New) $175.00 for all four
16. DC Sports polishe aluminum lower tie bar $60.00
17. Tanabe Sustec GF210 lowering Springs (brand New) $50.00
18. Infinity reference series 6 1/2 component system (Brand New) $50.00
19. Blue H22a valve cover with Honda gasket (Both Brand New) $100.00
20. LeBra leather hood protector, in good condition $35.00
21. OEM Center Console $75.00
22. OEM leather rear center piece with speaker cover. Comes with amp, mounting bracket, and a good condition Kicker 6x9 sub $100.00
23. OEM clothe seats in good condition Front $100.00 Rear $50.00
24. V-TEC selinoid with new Honda gasket $75.00
25. Front clear turn signals $15.00
26. Short shift adapter $15.00
27. OEM clothe door panels. Passenger side has a small tear (smaller than a dime) $70.00 for both
28. Tanabe Racing Medallion exhaust and high flow cat (great deep tone). It is good condition with no holes and their are no dents $125.00
29. SCE Copper head gasket. Lowers compression from 10:1 to 9:1. (Brand New) $135.00
---------------Randoms---------------
-S2000 style push button start (brand New) $10.00
-Valve adjustment tool (brand New) $5.00
-JDM Road Flare $10.00
-Throttle Body Spacer $20.00
-Manual Tensioner $15.00
-OEM Center Vent $10.00
-OEM Jack Cover $10.00
-OEM radio bezel $10.00
-Bosch o2 sensor (Brand New) $15.00
-(2) Bosch 440 fuel injectors from a Toyota Supra I was going to use as secondaries. $20.00
-Momo emergency brake handle and boot $40 .00
-Momo shift **** and boot (brand New) $40.00
-Momo Rest Pedal. $1.00
-Brand new rear engine mount
Old Aug 18, 2012 | 02:27 PM
Luded93's Avatar
Default Re: H22a1, Prelude Parts, and Misc
a few more items and pictures
Old Aug 18, 2012 | 04:07 PM
nirvanacarl's Avatar
do you have the shifter for it?
Old Aug 19, 2012 | 03:53 AM
gixer-racer's Avatar
How much for cam gears please would you ship to uk?
Old Aug 19, 2012 | 07:23 AM
bigbpatel's Avatar
Pm me prices shipped to 27513 please
Old Aug 19, 2012 | 07:06 PM
Luded93's Avatar
More pictures...
Old Aug 22, 2012 | 08:48 AM
bigbpatel's Avatar
bumpp for good seller
Old Sep 9, 2012 | 01:38 PM
mtseidl's Avatar
I'm needing a H22a1 crankshaft real bad. Any help would be great.
Old Oct 16, 2012 | 02:56 PM
Luded93's Avatar
Bump
Propulsion
Northern California (Sales)
Aug 4, 2007 03:04 PM
navin
154
Nov 14, 2003 06:38 AM
sircrxracer
Sep 24, 2003 09:34 AM
swarsing
Dec 2, 2001 09:17 PM
