B16a2 compression question
Old Aug 16, 2012 | 10:38 PM
kush_ek's Avatar
Default B16a2 compression question
So heres the problem. I just bought a b16a2 swap.did a compression check with a battery charger directly to starter. I got 150 for 3 cylinders and 170 for one. I got the swap for 1250 full swap out of a 99 si.so here is where I need some advise should I keep it and return it. I spun a bearing and left with out a car until I can find another legit motor. My old motor spun a main bearing.
Old Aug 16, 2012 | 10:54 PM
doood's Avatar
been there done that
Default Re: B16a2 compression question
the numbers arent so far off from one another that i would worry too much about it. did you do a wet test?
Old Aug 16, 2012 | 11:30 PM
kush_ek's Avatar
No wet test it's out of the car. could I do a wet test out of the car?I was thinking replacing head gasket do you think that would help
poppin-vtec
Oct 26, 2014 09:32 AM
DrGrEeNtHuMb
Apr 11, 2009 04:41 PM
lee0149
Feb 1, 2009 06:59 AM
Hoodwinked
May 14, 2004 08:28 AM
