odd power window problem 1999 civic lx
bought a 99 civic lx and the drivers side rear window was stuck down. i was getting no "clicking" from the motor when using either the driver window master switch or that particular rear door windows switch... so i bought a used unit (motor and regulator)... pushed the button down with it installed and hooked up, with the window glass not bolted to it yet (so i could get it down far enough to insert the bolts through the regulator and attach to glass)... it went down just fine. so after the glass was hooked up, i noticed the switch would not let the window go back up, so i pressed down again and the window went all the way down. still would not go up. when pressing down it would "click" for obvious reasons it was bottomed out. i swaped out a used switch i also had. same thing. only went down, not up. now it will not do anything, and i am not getting power to the motor from the switch. the fuse is good. any ideas?
92-CivicLX
Sep 23, 2013 07:46 AM
hondapwr
Jul 17, 2009 05:30 PM
