redlining early?
if i were to haul ***,I basically have to shift at 5k every gear.it will sputter and stop pulling like it is redlining at 5k.
once in a while(usually after a lot of downshifting or highway driving,i will get the o2 sensor code,but i dont think it is related because it will rev limit whether the code is on or not,and there is no cel that gets kicked on when it happens.
this is a 91 integra
b18a1 motor
b18b valves/stems/springs/retainers/keepers/rocker arms and cams in a polished/balance checked b18a1 head.
all turbo seal gaskets and o rings(soon to be turbo
)race piston rings and rod bearings
ecu is stock
since ive finished this build,i have replaced
distributor(salvage yard,so used)
main relay
gaskets and o rings ^
new motor grounds
misc wiring
timing belt
radiator(from a 94 dc)
i havent changed the oil filter since i got the car,so it is WEEELLLLL overdue for one,especially after having gone through an overheat and getting thick milky oil before this new headgasket swap..
also,ill just let this one out,because i dont KNOW for a fact if this would have anything to do with it or not.upon the build i f'd up two valve guides and in turn,had to remove one rocker arm from both of the intake cylinders,disabling the valve from opening(intake valves.it is temporary for now)..if there is a power loss,it is very,very unnoticeable,other than the fact that i cant make a full pull because it redlines early...
could this effect it?
I never got a chance to drive it before i built it, i bought it as a clunker basically lol.so all i can say is that it has been rev limiting like this for the entire time i have gotten to drive it.it only has,give or take, 60 miles on it.if even that.
b18a1 motor
ecu is stock
main relay
new motor grounds
misc wiring
timing belt
b18a1 motor
ecu is stock
main relay
new motor grounds
misc wiring
timing belt
b18a1 motor
ecu is stock
main relay
new motor grounds
misc wiring
timing belt
b18a1 motor
ecu is stock
main relay
new motor grounds
misc wiring
timing belt
i know what i am doing.if you saw it,youd be surprised,but it isnt as ghetto as it sounds.
i blew a headgasket yes,but since that i have replaced the gasket and had the head balance checked and polished once again.but since that blown headgasket,i just havent changed the oil filter..
now you know why i didnt want to reveal it lol.like i said,its temporary.
update:
i tried my friend's ecu from his 90 integra.i could get up past 5k.
but then i put my stock ecu back in...now it does not rev limit anymore..so im not so sure the ecu was the problem. now it is redlining as it should.maybe it only happens sometimes?i dont know.
im pretty sure its this oil filter.thanks for the help guys.
update:
Won't last long. With out the intake valve opening it is just puddle gas on the valves on that cylinder. During high rpm pulls, on day it will suck that valve slightly open and hydrolock the cylinder.
And the filter. Question: If you **** your pants and then take a shower. Would you put you shitty underware back on? How stupid can you be? I would shoot myself.
im on an extremely low budget,and needed other things more importantly..its not that big of a deal,it can be changed in a matter of minutes.calm down.
"During high rpm pulls, on day it will suck that valve slightly open and hydrolock the cylinder."..
.. are you just trying to sound smart?ill take into consideration your thoughts,but it does not mean i agree with you.
also,to let everyone know,i found the problem.my radiator has a tiny hole in it,and if i get on it hard,the rad. fluid sprays out through a tiny hole,causing me to lose pressure after the radiator hits damn near empty.it seems as if it is working like a major vacuum leak..
i also picked up a new oil filter,will be putting it on tomorrow.
thanks for the help HT.
Damn near blew coffee out my nose when I read about the hydro-lock, "it will suck that valve slightly open and hydrolock the cylinder" sometimes the "help" is stupid.
94
94
If you're pressurizing your coollant system during load, you have not fixed your head gasket. Any why would you ever run to redline with one intake valve broken?
Sounds to me like "I am broke, I have a broken engine, I want my broken engine to rev to 8K" Doens't make much sense, get some cents.
