B18b1 swap questions
Old Aug 16, 2012 | 11:55 AM
joshd_bh's Avatar
Icon6 B18b1 swap questions
Alright, so I'm doing an engine swap from a 96 Integra Ls into my 89 Civic Si. I've got most of the details figured out but want some opinions on the best route. I've done research using the search bar, so I'm looking for peoples opinions, not to get flamed because I asked a question.
What I already have:
-96 B18b1 w/ stock tranny
-Competion Stage 2 Clutch
-EFB2 Hasport motor mounts
-Hasport cable-hydro clutch cable conversion
-Hasport shift linkage
-B&M short shifter
-Phearable.net OBD1 ECU
What I want to know is how I should go about injectors and vacuum hoses. Since the B18 is a 96, it is OBD2 and I would need to get an injector jumper like so: http://www.rywire.com/catalog/obd1-h...ters-p-36.html I've heard that I can take out my old D16A6 injectors and use those, but the B18 ones are larger. On top of that, I believe Phearable.net specially programs the ECU for the Injector size. Should I get the Rywire jumper for $60? Or use my old injectors?
Now for vacuum hoses and that stuff-I have the MAP sensor on my firewall and one built into the intake manifold. If I used the sensor in the intake manifold, or throttle body (whatever), then how would I set up all of the vacuum hoses and for the charcoal canister?
Thanks!
Old Aug 16, 2012 | 06:44 PM
dylaxiin's Avatar
Default Re: B18b1 swap questions
get 90-91 integra injectors if your staying obd0.. get 92-93 integra injectors if converting to obd1. and as far as the vacuum lines, what i did was unplug all of them and just started plugged them in until the car idled at 750-1000rpms...
Old Aug 17, 2012 | 07:56 AM
joshd_bh's Avatar
I also have the OBD0 injectors off my 89 D16A6. Could I use those?
Old Aug 17, 2012 | 12:08 PM
dephtone's Avatar
According to this flow chart, all D and B series injectors flow the same amount. 245cc.
http://www.massivespeedforums.com/20...or-flow-rates/
So yes you can use your D16a6 injectors.
Old Aug 17, 2012 | 12:34 PM
solorex's Avatar
Use your stock injectors. Use the throttle body MAP on the new throttle body. If you want to keep your charcoal canister, hook it up the same way it was. You're LS TB will have vacuum on it.
jayjona8732
12
May 25, 2010 02:17 PM
perseverance
Nov 13, 2007 07:58 AM
immikejones
Sep 3, 2005 07:15 PM
zexdrex
Nov 6, 2003 11:12 PM
satan_srv
Aug 20, 2002 12:02 PM
