H22 Loud Valvetrain Noise, Valve Adjustment is in spec, Video
Old Aug 15, 2012 | 10:39 PM
Nisif's Avatar
Default H22 Loud Valvetrain Noise, Valve Adjustment is in spec, Video
I picked up a 97 Honda Prelude Type SH and the seller believed it had rod knock.
I drained the oil and fished a magnet in the oil pan. There was no evidence of any metal shavings typical of a bearing failure.
The noise is coming from cylinder 1 in the head. I checked with a stethoscope to pinpoint the noise.
So far I've adjusted the valves to spec. Intake at .007" and Exhaust Valves at .008". During the process I didn't notice anything that was damaged or looked/felt out of place.
Wondering what I should be looking for now. Bad LMA? Any common valve train issues with the H22?
Here's a vid...skip to 1:45 or around 2:00 and the noise is very audible. Don't mind the oil leak dripping onto the header, I didn't tighten all the valve cover nuts completely before shooting the video.
TIA
http://www.youtube.com/watch?v=8QiQ8...ature=youtu.be
Old Aug 18, 2012 | 04:02 PM
Nisif's Avatar
Default Re: H22 Loud Valvetrain Noise, Valve Adjustment is in spec, Video
Up
Old Aug 18, 2012 | 05:54 PM
JuicedUpRice's Avatar
are you throwing any codes?does the car drive fine?anything out of the ordinary other than that noise?
kinda sounds like something is loose and hitting something...but who knows..maybe a bent valve..
Old Aug 18, 2012 | 08:17 PM
SoL_ger's Avatar
bent valve.
Old Aug 18, 2012 | 08:19 PM
SoL_ger's Avatar
most likey skipped a tooth on the belt and bent the valve
Excelerate
Feb 9, 2011 04:45 AM
mtkhalid
16
Sep 29, 2008 10:47 PM
For_Sale
Jul 12, 2006 10:50 AM
mikeunreal2
Apr 21, 2006 10:15 PM
