Honda CR-V & Element 2WD & 4WD Element & CR-V
Problems with 99 UK CRV auto
Old Aug 15, 2012 | 09:15 PM
ontor's Avatar
Default Problems with 99 UK CRV auto
Hi
I have a 99 CRv
The D light will not illuminate. Its ok in 1 and 2
If you put it in D it just goes straight into and stays in top gear so to drive you need to put it into 1 then 2 then D
Also, tach is not working which Im sure must be connected to the above issue.
Heated Oxy sensor has reported a fault and this will explain the rich running so im onto that.
Any advice on the rev counter, is there a test port? method of testing?
many thanks
Al.
Old Aug 16, 2012 | 04:39 AM
el crapitan's Avatar
Default Re: Problems with 99 UK CRV auto
for the tach, you are correct, there is a test port. on mine (cdn) it is located on the drivers side underhood, near the cowl. it's a little capped off blue connector that's taped to the rest of the harness.
the tach signal is usually an output of the igniter, inside the distributor
strider380
Nov 11, 2010 09:51 PM
marks_lude
Apr 26, 2007 04:44 AM
laderj
Aug 17, 2006 02:38 PM
ibfunkee
Jan 22, 2006 06:56 PM
nighttime
Oct 26, 2002 02:21 PM
