D16 Project Part Out
Cooling System
Go-AutoWorks Aluminum Radiator
12" Slimline Fan
Mishimoto Silicone Hoses (Lifetime Warranty)
$225 Shipped
SC50 Precision Turbo
Under 3000 Miles
Great for 4 Cylinders
500WHP Capable
Clean, no oil leaks, no blown seals
No shaft play at all
.60/.63
T3 Flange
$650 Shipped
Go-AutoWorks A/C Compatible Ramhorn W/ DP
T3 4-Bolt Flange
38mm WG Flange
Lifetime Warranty, Superior Quality
Go-Autoworks Downpipe 2.5 inch flared to 3.
2 O2 Sensor Bungs and flex pipe
$1050 Shipped
60A Polyurethane mounts for EG civic and DC Integra.
For B and D series with hydro transmission
Billet aluminum mounts for Street/Strip
$250 Shipped
Go-Auto Works Intercooler and piping with couplers.
Mandrel bent piping with bead rolled ends and GReddy BOV flange.
2 inch diameter hot side, 2.5 inch cold side
The inter cooler filled out the entire grill on my EG coupe.
28x8x3.5
$400 Shipped
Sparco Harness bar with Mounting Hardware
Fits EG Civic and DC Integras
Genuine Takata racing Harness with Hardware
$550 Shipped
GReddy PRofec B Spec 2 Boost controller
Wastegate response adjustments
Large solenoid for high boost
Two boost setting presets
$300 Shipped
AEM High Flow Fuel Rail
AEM Adjustable Fuel Pressure Regulator
FPR has been rebuilt with new diaphragm from AEM.
Liquid filled Fuel pressure gauge with appropriate fitting.
$175 Shipped
GReddy Type RS blow off valve in great condition
With gasket and fasteners
Worked great, held 20psi no problem
$130 Shipped
1000cc Injectors
Less than 3000 miles
Low Impedance
Will fit most Hondas and Acuras
$275 Shipped
12" Slimline Fan
$225 Shipped
Under 3000 Miles
500WHP Capable
.60/.63
T3 Flange
$650 Shipped
T3 4-Bolt Flange
38mm WG Flange
$1050 Shipped
$250 Shipped
28x8x3.5
$400 Shipped
$550 Shipped
$300 Shipped
$175 Shipped
$130 Shipped
1000cc Injectors
Low Impedance
$275 Shipped
tommyj
Jun 21, 2009 06:04 PM
