1998 GSR Upper Water Neck Part Number?
Old Aug 15, 2012 | 02:02 PM
1998GsRIntegra's Avatar
Default 1998 GSR Upper Water Neck Part Number?
Hi guys and girls,
Does anyone have or know the part number for the water neck bolted to the head that the top radiator hose goes to? I can't find it in oem diagrams for anything. I have about 10 of the things in my "spare parts department" but none of them are a straight design like the gsr one, all the ones I have are at about a 35-45 degree angle which will put too much of a bend in the upper radiator hose. Mine sprung a leak at the bottom of metal portion that the heater hose connects to. Its actually spraying out of the metal piece where it is attached to the actual water neck. Kind of odd really.
Thanks for any help.
EDIT: Here's a picture if it helps anyone out: http://www.google.com/imgres?num=10&...9,r:2,s:0,i:82
Old Aug 15, 2012 | 02:25 PM
IN VTEC's Avatar
Default Re: 1998 GSR Upper Water Neck Part Number?
I've got one if you want it.
Otherwise...
19315-P72-010 COVER, WATER OUTLET
Old Aug 15, 2012 | 02:27 PM
I'm really looking to just buy a new one. I don't really want to buy an old one only to have this problem happen again in the not too distant future. Thanks for the offer though, appreciate it.
Old Aug 15, 2012 | 02:54 PM
HondaPartsHero's Avatar
Technical Hero
*6 19315-P72-010 COVER, WATER OUTLET 001 1998 INTEGRA 22.62 16.97 Qty:
Www.acuraautomotiveparts.org
Old Aug 15, 2012 | 03:19 PM
Thank you both, really appreciate it. Turns out it was under the one section I would have never thought it to be under and the one section related to the cooling system that I didn't check, figures...Water Pump.
mac_24_seven
Dec 29, 2008 01:27 AM
Ohmster
Apr 21, 2008 05:13 PM
MI4$DC5
Dec 29, 2006 08:22 PM
screen_name
Apr 30, 2005 05:54 PM
legendboy
Jun 1, 2004 06:35 PM
