Eg wheel bearing bad??? Grinding noise?
Old Aug 15, 2012 | 01:35 PM
Iloveyourhonda92's Avatar
Icon2 Eg wheel bearing bad??? Grinding noise?
So awhile ago when i was taking out the axle i put everything back together and noticed a slight grinding sound(sounds like metal to metal contact), this sound only happens when i hit aggressive bumps and when i take hard turns but only from the drivers front side. I thought it may have been the rotor so i just replaced the rotor/brake pads, still sounds pretty bad, i checked the dust shield and its pushed as far back as it can go. I dont hear the noise when im doing straight on smooth roads, or like the freeway i cant hear it. So would it be the wheel bearing or something else? the rotors i put on were just resurfaced as well. I remember hitting the hub to get the lower ball joint to free up, so im thinking i might have hit it too hard to mess the wheel bearing up.. Not sure though, any input?
fortified55
Suspension & Brakes
Oct 21, 2015 10:29 AM
avio
Apr 16, 2010 12:51 AM
jkalex05
Nov 23, 2009 06:52 PM
schpiel
Sep 17, 2007 07:28 PM
Monkey Fing a Coconut
Oct 24, 2003 10:45 PM
