A/C Problems
Old Aug 15, 2012 | 12:30 PM
CaseyB's Avatar
Default A/C Problems
2000 Honda civic
when air conditioning is turned on engine seems to loose horse power and it makes a chirping noise under hood and inside cabin near glove box
Old Aug 15, 2012 | 01:03 PM
Former User's Avatar
Default Re: A/C Problems
Does the A/C work well? Does the condenser fan run? If so, tighten or replace the A/C belt.
Old Aug 15, 2012 | 02:08 PM
Bashismashi's Avatar
I believe I had this same problem a few months back, and for me it was the A/C compressor was locked up. It started as a small noise at first, kind of sounded like a piece of paper was being hit by the fan or something, and eventually it got to be a horrible sound and when I turned on the AC you could seriously feel it throttle down the engine really bad. Finally I bought a new compressor myself and had it installed and then the problem went completely away.
Old Aug 15, 2012 | 05:58 PM
LownSlowEkd16's Avatar
It could very well be the belt. Either adjust the tensioner or replace the belt.
Old Aug 17, 2012 | 08:09 PM
CaseyB's Avatar
the a/c is not as cold as it used to be...already replaced the compressor about a year ago. I had the belt looked at while fixing another problem and the mechanic said it was fine
Old Aug 17, 2012 | 08:10 PM
You need a manifold gauge set to measure the pressures on the low and high sides --->
Old Aug 17, 2012 | 08:19 PM
eastbay92cx
Apr 8, 2011 04:28 PM
funtus85
Jun 25, 2010 01:15 PM
october_red
Nov 22, 2008 10:07 AM
DBAl
Jul 20, 2006 09:17 AM
blaze the chemi
Jan 26, 2006 06:07 PM
