FS: k24 block and k20 parts
Contact: *305 496 8407 **
Item Description: *
K24 shortblock $500
k20 OEM fuel rail with injectors $40
k20z3 cams $50
k20a2 cams $50
50 Degree VTC Cam Gear $45
k20z3 oil pan $60
k20a2 counter shaft $100
k20a2 Flywheel Sold
Read descriptions with the pics. **
Photos:[B] *Mint k24a8 complete shortblock purchased from the junk with 32k miles. I installed the k20a water assembly and k20a oil cooler. Block is complete with timing cover, tensioner, chain guides, crank, piston/rods. I took off the oil pump and threw it away since its useless. I was going to upgrade it to a k20a pump. I used a block just like this for my Red kswapped EM1 and only slapped in RS Machine 12:1 pistons and it made 263whp/200 trq. Asking $500
Motor before it was stripped...
k20z3 cams $50
k20a2 cams $50
k20z3 oil pan $60
k20a2 counter shaft with bad 2nd gear. The rest of the gears look good. $100
Item Description: *
K24 shortblock $500
k20z3 cams $50
k20a2 cams $50
k20z3 oil pan $60
k20a2 Flywheel Sold
k20z3 cams $50
k20a2 cams $50
k20z3 oil pan $60
ltrkstr2k
Mid-Atlantic (Sales)
Oct 11, 2012 03:26 PM
