tire size question
Old Aug 14, 2012 | 07:37 PM
hillbillycivic's Avatar
Icon2 tire size question
right now i have 205 40 r17 tires on my civic i want to put 15s on it to get it a little lower to the ground. 2 in smaller wheels will drop it an inch as long as the tire sidewall profile stays the same.
40% of 205 is 82mm but i went to tires rack .com and couldnt find any tires that fit a 15in wheel with a sidewall of 82mm or less they where all more. tire width dosnt really concern me as long as it fits most standard 7in or 8in wheels.
so what are the standard lowprofile tire sizes and is there one that fits what im looking for in a decent price range??
Old Aug 14, 2012 | 08:34 PM
toyomatt84's Avatar
Sanji
Default Re: tire size question
The car dictates the tire size more so then your wheels. What year/model Civic are you referring to?
Old Aug 15, 2012 | 04:52 AM
6thgenftw's Avatar
yeah we need some car facts OP
Old Aug 15, 2012 | 09:27 AM
its a 98 coupe with 1.5-2in drop (cant tell was there when i baught it) i just want it lower now and smaller tires for when i save up for coilovers.
195 45 15 where the smallest but only one tire was availible and i dont realy want a size thats that hard to replace.
Old Aug 15, 2012 | 09:47 AM
TunerN00b's Avatar
195/55-15 is the correct 15" tire size for that car. If you want the car lower, then adjust the height through the spring perch and/or length.
Tire diameter affects the odometer and speedometer accuracy.
Ignoring that, the smaller diameter tires won't have the same load rating, which might be dangerous to drive on.
Old Aug 15, 2012 | 09:59 AM
6thgenftw's Avatar
the recommended tire sizes for your car are 195/55/15 or 205/50/15. Im running a 195/50/15 on my si wheels and it throw my speedometer off a little bit but im pretty slammed and a 195/55 rubs. I would never use a 195/45/15 though... :/
Old Aug 15, 2012 | 11:52 AM
doc@tirerack's Avatar
your 205/40R17 is 23.5" in diameter, just like a 195/55R15. The 195/45R15 tire size you referenced is too small and does not have sufficient load capacity to be safe / durable. You'll need to go the lowering spring / coilover route to lower the car.
mikebaker422
Jul 10, 2013 11:45 PM
jdm_j03
Apr 24, 2009 07:27 AM
forvendetta
Feb 15, 2007 04:39 PM
7808
May 27, 2006 10:01 PM
OldSchoolHatch
Aug 27, 2002 03:01 PM
