94 Accord EX problems w/pics
Old Aug 14, 2012 | 09:30 AM
KolonelKoRn's Avatar
Default 94 Accord EX rear suspension issue
Hey guys, I'm new here and have come here previously through the power of google
I was wonderng if anyone could point me directly to what I need and I have searched.. I'm looking for the part that connects the shock to the rest of the car. The LCA is not it.
Thanks
Last edited by KolonelKoRn; Nov 6, 2012 at 06:02 AM. Reason: New issue and did not want to make new thread
Old Aug 14, 2012 | 08:52 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 94 Accord EX problems w/pics
When an aftermarket air filter replaces the stock air filter housing, resonator chamber, and flow tube the vacuum controls are no longer needed for the chamber.
Check out AEMs air intake instructions...
http://www.aemintakes.com/instructio...1-408_inst.pdf
That should help clarify what vacuum hoses are no longer needed.
Old Aug 14, 2012 | 10:11 PM
Ahhhhhhh, I see. The third, bottom of the three should be fine then? That one connects to something. Other than that and the squealing everything under the hood should be good then.
Old Nov 6, 2012 | 06:03 AM
Bump for another problem. Did not want to make another thread.
Old Nov 7, 2012 | 09:40 AM
MAD_MIKE's Avatar
MM Gruppe B
Uh, then why not just add your new question to the thread rather than editing the first? A bit of uncouth forum etiquette.
Post # 4 should be
Thanks
Not...
It keeps the thread clear and concise for future searches, and it doesn't make me look like a lunatic answering a suspension question with a CAI answer.
As for your suspension question, the shock/spring assembly are bolted directly to the body at the shock tower.
The lower portion is attached to the lower control arm via the fork.
You can look up diagrams from Majestic Honda.
http://www.hondaautomotiveparts.com/...artsSearch.jsp
Here is the front lower suspension components on a 94-97 Accord...
#19/20 are what I believe you are trying to identify.
51811-SV4-010 019 FORK, R. FR. SHOCK ABSORBER List-91.95 Sell-64.37
51821-SV4-010 020 FORK, L. FR. SHOCK ABSORBER List-94.07 Sell-65.85
maxi15
Dec 21, 2007 10:56 PM
quazzibell
Nov 5, 2006 11:09 PM
dafranchise69
Oct 20, 2005 09:31 AM
macdian
Sep 22, 2005 06:59 PM
txwylde
Apr 21, 2005 08:11 AM
