EF9 INSPIRED PART OUT! B20VTEC, EF9 FRONT, Y1 MUGEN LSD, TEIN, CUSCO
located in the 626.
all prices are obo, lowballers will be ignored.
major ef part out!
sergio 626.905.4420
IM ONLY LOOKING FOR CASH, THE ONLY TRADES ILL ACCEPT ARE CASHH HAA!
perfect B20vtec w/ 00' High comp B20B block & complete 00' JDM ITR head COMPLETE SWAP with toda flywheel & act stage one clutch disk, tri y header, ctr crank pulley, 3" intake with BPI velocity stack, hks spark plugs & chipped p08 ecu. everything for -$3000; the more YOU lower the price, the more parts im taking off to make up for it.
NEW OEM parts used when building-
Cap
Rotor
ITR water pump
ITR timing belt
ITR oil pump
intake manifold gasket
exhaust manifold gasket
oil pan gasket
thermostat w/ gasket
valve cover gasket
MINT MINT JDM Y1 B16 trans with AUTHENTIC MUGEN LSD- $1000 with electric speed sensor.
ef b series HASPORT shift linkage w/ prothane shifter bushings- $60
OEM GSR shifter (oem short shifter) - 30
Skunk2 50th anniversary shift **** - 30
SUSPENSION/BRAKES
JDM ITR TEIN RA Coilovers 14k/10k needs to be rebuilt - 500
JDM ITR Rear LCA - 40
EG/DC front strut forks - 10
Prothane sway bar endlinks 20
Prothane steering rack bushings 20
Prothane Radius rod bushings 20
Skunk2 pro series front camber kit needs new ball joints - 80
Skunk2 rear camber kit - 60
Cusco Rear strut bar 100
EF9 Front big brake conversion 10.2" - 100
00' GSR Rear disk conversion - 100
91 integra brake booster mint 40
91 integra master cylinder 40
91 integra 40/40 proportioning valve 20
INTERIOR/EXTERIOR
EF9 cluster 150
626 905 4420; text for fastest response
major ef part out!
sergio 626.905.4420
Cap
Rotor
ITR water pump
ITR timing belt
ITR oil pump
oil pan gasket
valve cover gasket
SUSPENSION/BRAKES
INTERIOR/EXTERIOR
EF9 cluster 150
pics of the front camber kit....send to fernandof19@gmail.com
seats pending
theyre on the car so i dont have a pic but theyre good tho, not damaged, bent or anything. Its just the upper ball joints need replacing but theyre like 35-40 each
iheartjayDem
Jan 16, 2013 12:50 PM
iheartjayDem
Aug 29, 2012 09:03 AM
iheartjayDem
Jun 15, 2012 06:30 AM
