EF9 INSPIRED PART OUT! B20VTEC, EF9 FRONT, Y1 MUGEN LSD, TEIN, CUSCO
Old Aug 14, 2012 | 09:26 AM
iheartjayDem's Avatar
Default EF9 INSPIRED PART OUT! B20VTEC, EF9 FRONT, Y1 MUGEN LSD, TEIN, CUSCO
located in the 626.
all prices are obo, lowballers will be ignored.
major ef part out!
sergio 626.905.4420
IM ONLY LOOKING FOR CASH, THE ONLY TRADES ILL ACCEPT ARE CASHH HAA!
perfect B20vtec w/ 00' High comp B20B block & complete 00' JDM ITR head COMPLETE SWAP with toda flywheel & act stage one clutch disk, tri y header, ctr crank pulley, 3" intake with BPI velocity stack, hks spark plugs & chipped p08 ecu. everything for -$3000; the more YOU lower the price, the more parts im taking off to make up for it.
NEW OEM parts used when building-
Cap
Rotor
ITR water pump
ITR timing belt
ITR oil pump
intake manifold gasket
exhaust manifold gasket
oil pan gasket
thermostat w/ gasket
valve cover gasket
MINT MINT JDM Y1 B16 trans with AUTHENTIC MUGEN LSD- $1000 with electric speed sensor.
ef b series HASPORT shift linkage w/ prothane shifter bushings- $60
OEM GSR shifter (oem short shifter) - 30
Skunk2 50th anniversary shift **** - 30
SUSPENSION/BRAKES
JDM ITR TEIN RA Coilovers 14k/10k needs to be rebuilt - 500
JDM ITR Rear LCA - 40
EG/DC front strut forks - 10
Prothane sway bar endlinks 20
Prothane steering rack bushings 20
Prothane Radius rod bushings 20
Skunk2 pro series front camber kit needs new ball joints - 80
Skunk2 rear camber kit - 60
Cusco Rear strut bar 100
EF9 Front big brake conversion 10.2" - 100
00' GSR Rear disk conversion - 100
91 integra brake booster mint 40
91 integra master cylinder 40
91 integra 40/40 proportioning valve 20
INTERIOR/EXTERIOR
EF9 cluster 150
626 905 4420; text for fastest response
Old Aug 14, 2012 | 09:38 AM
SILENTVTEC's Avatar
Default Re: EF9 INSPIRED PART OUT! B20VTEC, EF9 FRONT, Y1 MUGEN LSD, TEIN, CUSCO
ttt!
Old Aug 14, 2012 | 09:43 AM
aftermath1312's Avatar
Bump
Old Aug 14, 2012 | 09:49 AM
weaksoN!'s Avatar
ttt
Old Aug 14, 2012 | 09:56 AM
thanks guys!
Old Aug 14, 2012 | 10:12 AM
EusebioSam19's Avatar
Hey will those front spindles fit DA?
Old Aug 15, 2012 | 06:15 AM
bump
Old Aug 15, 2012 | 07:42 AM
RoTb TwEaK's Avatar
Bump for some really nice parts
Old Aug 15, 2012 | 01:00 PM
thankss
Old Aug 15, 2012 | 02:49 PM
da9blk1's Avatar
TXTd
Old Aug 15, 2012 | 04:31 PM
EVIL EF9 RHD's Avatar
bump
Old Aug 15, 2012 | 07:38 PM
xELxCHIDOx's Avatar
Bumppppp
Old Aug 15, 2012 | 09:43 PM
ej8hybrid's Avatar
bump
Old Aug 16, 2012 | 07:28 AM
thanks for the bumpsss
Old Aug 16, 2012 | 11:06 AM
xxOldschoolxx's Avatar
Textd
Old Aug 16, 2012 | 11:38 AM
SIKNASTREXO's Avatar
need the 91-prop valve, booster and mC,,,mayb the rear breaks
that mugen LSD,, any pics...
text 323 6301900
Old Aug 16, 2012 | 12:32 PM
ciscobyer's Avatar
bump
Old Aug 16, 2012 | 01:04 PM
mugen lsd is in my y1 b16 trans, ill text you
Old Aug 17, 2012 | 08:11 AM
bump
Old Aug 18, 2012 | 12:24 AM
Short hub & camber kits fit da?
Old Aug 20, 2012 | 11:37 AM
mm unsure, bump
Old Aug 20, 2012 | 12:00 PM
artiecubz's Avatar
Old Aug 20, 2012 | 04:18 PM
da9bro's Avatar
price for front and rear camber kit shipped to virginia? would probably fit in a usps flat rate box which is only like $15
Old Aug 21, 2012 | 12:10 AM
My94Ej1's Avatar
has anything been sold?
Old Aug 21, 2012 | 07:11 AM
yeah, the ef9 front end, ef9 arm rest, usdm optional center consol, rear mud flaps. will update shortly.
