Eg parts! misc garage sale
whats up guys i have a bunch of parts laying around in my garage and need to get rid of it all by friday!!! so hit me up low ballers welcome
i have 92-95 eg
Dark blue and some gray interior pieces mint!
Steering column cover
Doorsteps
cupholder everything
Clean oem Dark Blue steering wheel
DA/accord lip
hazard switch
X2 EG hatch wings with brake lights
Clean Center console Delete with rubber Ebrake boot
D series Powersteering
integra calipers to do eg big brake kit super clean Gold!!!
S2000 Redrilled 4X100 12" rotors front and rear oem
d series upper exuast manifold piece one for cat
Dseries stock manifold wdownpipe cracked but can be welded or filled in
stock shifter
door steps or what ever there called
a bunch of distributor caps and a couple rotors
jdm D15B intake manifold with throttle body super clean internals with injectors
Si passenger door Green with molding Mint condition!!!
Dseries spark plug wires working condition
Civic horns
and probably more stuff i can't think of
Ontario/Upland
HMu 909 851 2141
i have 92-95 eg
Doorsteps
DA/accord lip
hazard switch
stock shifter
Civic horns
Ontario/Upland
HMu 909 851 2141
do you have the strip on the outside of the drivers door and a glovebox? also tell me more about the s2000 brakes, what do i need to run those
you need EX/Si i think even Dx spindles are fine cus tohe models stock use bigger calipers but yea throw these on with some good calipers and you have yourself some amazing brakes, check the sticky for Brake expert you will see
